3D object import issue
This topic has been viewed 6202 times and has 3 replies
jllh76
Post by jllh76 »
I would like to import this object but there is a point in the original file which prevents me from importing it properly.
Could you please help me have a clean file and tell me how you managed to do it by myself next time?
Thanks in advance
https://3dwarehouse.sketchup.com/model/0e214eab-7fd4-4963-8663-bf0d6900c6b8/tv-samsung-85
Re: 3D object import issue
I could import your file without problem. If you want to center the TV in its box, you should import it in Blender where you'll be able to edit all the vertices you want, then export it to OBJ format to import it in Sweet Home 3D.
Sweet Home 3D isn't able to make such modifications.
Drag the downloaded zip in your 2dView, export it as obj, import the obj.
edit: I looked at the file in Blender but didn't see anything wrong.
The export/import fixed the wide bounding box the collade file showed.
jllh76
Post by jllh76 »
Thanks to both of you for your quick responses (as usual).
Thanks Keet for your tip, it worked for me too.
