Feat. Req: Automatically measure all walls
This topic has been viewed 5773 times and has 2 replies
Olaf_Noehring
Post by Olaf_Noehring »
Hi
I have used Roomarranger in the past. A great feature there is to automatically measure all walls - saves a lot of work.
Olaf
c_sanz
Re: Feat. Req: Automatically measure all wall
Post by c_sanz »
The tool "Create dimensions" has no dependence on an object, dimensions are totally free, so therefore the magnetism of these does not work on the walls.
This function is not provided in the near future.
Greeting,
Christian.
mark
Re: Feat. Req: Automatically measure all walls
Post by mark »
If "measure" means something like total length of all walls or area wouldn't it be pretty easy to make a plugin and then just run from the menu ? i.e. like volumeplugin.
Something like ....
VolumnePlugin.java
public void execute() {
  float volumeInCm3 = 0;
  double  wallLength = 0;
  double totalWallLength = 0;
  StringBuffer wallDimensionsMsg = new StringBuffer();
  for (Wall wall : getHome().getWalls()){
    if (wall.getXStart() == wall.getXEnd()) {
      wallLength = wall.getYStart() - wall.getYEnd();
    } else if (wall.getYStart() == wall.getYEnd()){
      wallLength = wall.getXStart() - wall.getXEnd();
    } else {
      wallLength = Math.sqrt(Math.pow((wall.getXEnd()-wall.getXStart()),2)
          + (Math.pow((wall.getYEnd() - wall.getYStart()),2)));
  // get rid of negative values
  wallLength = ((wallLength < 0 ? -wallLength : wallLength));
  totalWallLength+=wallLength;
  wallDimensionsMsg.append("Wall: length " + wallLength + "\n");
  wallDimensionsMsg.append(String.format("  Total wall length = %.2f cm", totalWallLength));
  JOptionPane.showMessageDialog(null, wallDimensionsMsg);
Output would be " Total wall length = 1455.00 cm"
Excuse me if I got the wrong end of the stick :)
ta
mark
