Hi
I have used Roomarranger in the past. A great feature there is to automatically measure all walls - saves a lot of work.
Olaf
Feat. Req: Automatically measure all walls
This topic has been viewed 5591 times and has 2 replies
Olaf_Noehring
Re: Feat. Req: Automatically measure all wall
The tool "Create dimensions" has no dependence on an object, dimensions are totally free, so therefore the magnetism of these does not work on the walls.
This function is not provided in the near future.
Greeting,
Christian.
Greeting,
Christian.
Re: Feat. Req: Automatically measure all walls
If "measure" means something like total length of all walls or area wouldn't it be pretty easy to make a plugin and then just run from the menu ? i.e. like volumeplugin.
Something like ....
VolumnePlugin.java
Output would be " Total wall length = 1455.00 cm"
Excuse me if I got the wrong end of the stick
ta
mark
Something like ....
VolumnePlugin.java
public void execute() {
float volumeInCm3 = 0;
double wallLength = 0;
double totalWallLength = 0;
StringBuffer wallDimensionsMsg = new StringBuffer();
for (Wall wall : getHome().getWalls()){
if (wall.getXStart() == wall.getXEnd()) {
wallLength = wall.getYStart() - wall.getYEnd();
} else if (wall.getYStart() == wall.getYEnd()){
wallLength = wall.getXStart() - wall.getXEnd();
} else {
wallLength = Math.sqrt(Math.pow((wall.getXEnd()-wall.getXStart()),2)
+ (Math.pow((wall.getYEnd() - wall.getYStart()),2)));
// get rid of negative values
wallLength = ((wallLength < 0 ? -wallLength : wallLength));
totalWallLength+=wallLength;
wallDimensionsMsg.append("Wall: length " + wallLength + "\n");
wallDimensionsMsg.append(String.format(" Total wall length = %.2f cm", totalWallLength));
JOptionPane.showMessageDialog(null, wallDimensionsMsg);
}Output would be " Total wall length = 1455.00 cm"
ta
mark
