[Q] Merge several plans
This topic has been viewed 3980 times and has 9 replies
Hi sweeties!
Although my question should not be hard to be answered, I didn't find any solution via FAQ or google.
Question: I made plans of several rooms separately. Now, I want to make a new plan "my flat" merging all the single plans into "one" single plan. How this can be done?
As a first guess, I marked all objects of a room and copied them into the clipboard. But, creating a new plan (the "big one") opens a new window (instead opening a new plan as a new TAB inside the already running application). Within the new plan, the "paste" option is inactive, so I can't paste the content of the clipboard.
Any idea? What I am doing wrong?
Any help is appreciated.
Re: [Q] Merge several plans
You can have more than one instance of SH3D running at the same time. Copy in #1, than paste in #2.
- dorin
On the new plan click on plan window or on furniture list then You could paste what You have in clipboard.
Hi, it says this doesn't work on Linux maybe, and unfortunately it doesn't. So is there another option?
What error or unexpected behavior do you get?
Same problem here. Have 2 instances open. Copy a wall in one and try to past into the other. But nothing happens.
LinuxMint20 cinnamon, SH3D 6.2
Open the second instance from the first one, with File > Open or File > Open recent, and be sure to give the focus to the plan in the document where you want to paste items.
Can confirm that the last advice is working! Thanks for a useful program with many features.
This nifty trick should go into the help manual...
There is a nifty trick as I discovered using it.
The opened 2nd instance needs more then one level. If it has 2 levels, I can only copy to level 0.
Something I can live with once I know it. I use it as I designed a 4 storey villa. To create the interior with furniture and wallpaper I copy each storey into an extra file. This way my file size stays smaller too.
