[Q] Merge several plans
This topic has been viewed 3754 times and has 9 replies
docsnyder
Country: Germany
Post by docsnyder »
Hi sweeties!
Although my question should not be hard to be answered, I didn't find any solution via FAQ or google.
Question: I made plans of several rooms separately. Now, I want to make a new plan "my flat" merging all the single plans into "one" single plan. How this can be done?
As a first guess, I marked all objects of a room and copied them into the clipboard. But, creating a new plan (the "big one") opens a new window (instead opening a new plan as a new TAB inside the already running application). Within the new plan, the "paste" option is inactive, so I can't paste the content of the clipboard.
Any idea? What I am doing wrong?
Any help is appreciated.
Re: [Q] Merge several plans
You can have more than one instance of SH3D running at the same time. Copy in #1, than paste in #2.
dorin
Post by dorin »
On the new plan click on plan window or on furniture list then You could paste what You have in clipboard.
Shroom
Post by Shroom »
Hi, it says this doesn't work on Linux maybe, and unfortunately it doesn't. So is there another option?
What error or unexpected behavior do you get?
otadmin
Post by otadmin »
Same problem here. Have 2 instances open. Copy a wall in one and try to past into the other. But nothing happens.
LinuxMint20 cinnamon, SH3D 6.2
Open the second instance from the first one, with File > Open or File > Open recent, and be sure to give the focus to the plan in the document where you want to paste items.
otadmin
Post by otadmin »
Can confirm that the last advice is working! Thanks for a useful program with many features.
harbinger
Country: Clearwater, FL, US
Post by harbinger »
This nifty trick should go into the help manual...
otadmin
Post by otadmin »
There is a nifty trick as I discovered using it.
The opened 2nd instance needs more then one level. If it has 2 levels, I can only copy to level 0.
Something I can live with once I know it. I use it as I designed a 4 storey villa. To create the interior with furniture and wallpaper I copy each storey into an extra file. This way my file size stays smaller too.
Users browsing this forum: DuckDuckGo [Bot], Forester_Sk, MSN [Bot]
