Photo-video rendering plug-in
This topic has been viewed 2368942 times and has 240 replies
Re: Photo-video rendering plug-in
This doesn't work...
- right-click on the Windows logo
- select Run
- java -Xmx8g -jar C:\Users\hans\Downloads\SH3D-6.2_derived.jar
- nothing happens
Any suggestions?
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
Not sure if it works on Windoof, but go to your SweetHome3D directory, open the lib folder, rename the SweetHome3D.jar to anything else, rename the JAR-file from Enko to SweetHome3D.jar and copy it to the lib folder in your SweetHome3D directory.
Then start your SweetHome3D as usual...
Pascal
enkonyito
Post by enkonyito »
- select Run
- nothing happens
Any suggestions?
You can launch the JAR file
- from a terminal:
java -Xmx8g -jar "C:\Users\hans\Downloads\SH3D-6.2_derived.jar"
- from a .bat file in the same directory as the JAR:
java -Xmx8g -jar SH3D-6.2_derived.jar
Enko
EnkoNyito
enkonyito
Post by enkonyito »
This beta version 1.8 of the photo plug-in will allow you to test the new shininess shaders and Sunflow standard options from version 1.2 of this other plug-in (Tools menu).
[Note: Updated download links to include video rendering and bug fixes in standard options.]
AdditionalSunflowOptions-1.2a.sh3p
(69.33 KiB) Downloaded 1267 times
PVR-1.8_betaTest2a.sh3p
(345.51 KiB) Downloaded 439733 times
AdditionalSunflowOptions-1.2.sh3p
(69.27 KiB) Downloaded 1206 times
PVR-1.8_betaTest2.sh3p
(345.57 KiB) Downloaded 375307 times
EnkoNyito
Country: Copenhagen, Denmark
Post by Ceciliabr »
Perfect!
After some testing, I have found that a buffer size of 48 is marginally faster than 64 and 32.
Is it automatically detecting the number of threads available?
Quite oddly, it seems that choosing different bucket orders has an impact on the rendering time.
This is rendered with column.
Hilbert : 39 s
Spiral : 39 s
Row : 38 s
Column : 35 s
Diagonal : 35 s
Random: 48 s
I didn't try the reverse options – but I must admit I was somewhat curious about the reverse random...
I noticed no difference with the threads.lowPriority activated.
The project file is meant as an illustration of the rather hot inner core of the earth (intended for the education of my daughters),
and I wanted it to spin, so I tried making a video.
It seems the video will not render in Q4, but stops about half way.
I'm including the project file, in case anyone wants to give it a try ( 1280 x 536 )
Project file
enkonyito
Post by enkonyito »
@Ceciliabr
Yes, the number of threads by default is the number of available processors (CPU) that will be the maximum value because I noticed a bug by opening your file on my computer which has only 4 cores.
I think it depends on the scene.
With yours where the subject is central and the background black, the order has an influence especially on the calculation of the remaining time.
The "reverse random" bucket order will be removed.
This is what I also found but I do not do any action in the plan or the 3D view during a rendering.
Version 1.7 of the plug-in uses only the default values of the new options.
I will test with different video format because the lighting significantly increases the duration of the rendering.
Enko
EnkoNyito
Post by Ceciliabr »
I have tested, and tested, and tested again, and again, and I have found nothing wrong.
PVR-1.8_betaTest2, in companion with Additional Sunflow options (v1,2), works like a charm, and the combination is surely a blessing for everyone concerned with advanced rendering.
Myself, I would rather that the semi-transparent part of an uncompleted rendering could be completely transparent, but it works perfectly well like it i is!
In my opinion, PVR-1.8_betaTest2 is a release candidate (if it hasn't already been released without my knowledge)
Thank you for your great work!
Cecilia
waleedfahmy
Country: Egypt
Post by waleedfahmy »
I wish if one of experts make a detailed tutorial about rendering and setting . I get good results but after many trials and not totally satisfied with results
enkonyito
Post by enkonyito »
@Ceciliabr
Regarding the problem of video rendering, everything works correctly?
On my side it's random for a new simple project: a single object and a linear or circular camera path.
It is possible but I did not propose it because we do not see the size of the image.
Image Image
If everything is good on your side, I think that [font=courier new]version 1.8[/font] will soon be published.
The next big innovation will be the addition of the YafaRay rendering engine when its beta phase is over.
Enko
EnkoNyito
enkonyito
Post by enkonyito »
@waleedfahmy
VeroniQ has created a blog tutorial "How to create a nice photo rendering" and a video tutorial "How to create nice photo renderings".
Ceciliabr has created a detailed tutorial explaining his techniques and tips for a photo-realistic rendering.
For the description of the Sunflow rendering parameters, you can consult this document.
EnkoNyito
