The render does not show the night sky (black sky)
If I use the Sunflow engine to render the image, then it does not show the black sky.
When rendering, I specify the night time, for example 03:00 . Everything around is dark, without sunlight, but the sky is colored in the default color. White.
But if I take a picture during the day, at dawn, or sunset, then everything works well. If I use the standard engine of the program when rendering, then the sky is shown black at night, as it should be.
What can I do?
the night sky does not work. Photo-video plug-in
This topic has been viewed 3865 times and has 3 replies
segamega90
- Daniels118
- Country: Italy
Re: the night sky does not work. Photo-video plug-in
Have you tried to change the sky color? Right click on the 3D view, modify 3D view...
segamega90
Yes. This method brings results. But I thought that the program itself should change the color of the sky. Basically, she does it during the day, at sunset and at sunrise, changing color depending on what time I set. But for some reason it doesn't work at night. Although yafaray and the standard engine shows me a black night.
If you use a texture image for the sky, it will always be used at the two best quality levels in virtual visit, whatever the hour of the day. In other cases, this could mean that you didn't select the right time zone in the compass modification panel.
