High priority Need to deploy on Tomcat serer
This topic has been viewed 23197 times and has 41 replies
Re: Need to deploy on Tomcat serer
.. online System for the Electricians to design Lights, Sockets and A/C systems for a selected Floor Plan. The application reads the PDF files and can detect the Floor Plans.
Sounds interesting. You have probably noticed that the question of electric symbols appear from time to time: e.g. 5531: 2D Symbols and the 5416: Schneider project. If your work results in something of interest, it would be great if you would post something about it. And good luck. ok
prabath
Post by prabath »
Ys of Course. I'm really interesting. I'll look in to that
prabath
Post by prabath »
Hi Puybaret
Can you pls help to add a button as requested above?
Thanks for giving details about your goals. [:)]
If you want to add a button to the applet toolbar, you should override createHomeController method in the subclass of AppletApplication you started before.
Once you retrieved super implementation, inspire yourself of the (not so cleaned) existing implementation to retrieve the toolbar and add a button to it.
prabath
Post by prabath »
Thank You Puybaret.....
prabath
Post by prabath »
Hi Pyubaret
I enhanced my application to detect the lines of the Floor plan which is in the grid. I used Boof CV(http://boofcv.org/index.php?title=Main_Page)
libraries to do that. For the moment, it doesn't support all the floor plans. I'm improving the my line detecting algorithm.
But when I deployed the application on server(as a web application) with new feature, it says BoofCV libraries can't be found. I added BoofCV libraries under "otherLibraries" Tag in build.xml file. It
compiles perfectly, but when it runs as a web application , it can't load added Boof CV libs. I would be thankful , if you tell me if there is another way to
add libraries.
Thank You..
prabath
Post by prabath »
Hi Pyubaret ...
I think you will help me on this. I'm bit stuck on this
Thank You
Manage the new library as the other ones of Sweet Home 3D. Llook how batik-svgpathparser-1.7.jar is handled for example, and keep in mind that in applets environment you'll have to update JNLP file as well as applet HTML code.
prabath
Post by prabath »
Thank..... You Puybaret ......., It's working
prabath
Post by prabath »
Hi Puybaret....
If you allow me , I would like to answer the questions which are publish in this forum and help the others..
Please let me know your decision....
