big grin My photos on the wall..
This topic has been viewed 24367 times and has 18 replies
kumax
Re: My photos on the wall..
Post by kumax »
Thanks for the nice comment! [:">]
___________
Another render for my another friend. Big photo print on the wall.
I wish the quality of shadows and textures would be better but the floor is perfect!! [=D>] Thank you advanced photo render. [;)]
Very nice. [:)]
I'm looking forward discovering the picture you'll submit to Sweet Home 3D contest. 6 days left before the end! [;)]
db4tech
Country: UK
Post by db4tech »
Another great looking render! [:)]
What is it about the shadows that you'd like to change, the hardness? Also the textures?
db4tech
sanjoyp
Country: Scotland, UK
Post by sanjoyp »
Hi sorry for the thread hijack. I am running in to problems with my photos I have made into paintings on the wall ? I have found that those taken from gifs are okay but when the jpg resolution is high 2000+ * 2000+ pixels I am unable to render. I get the dreaded red x, memory issue ?
This image has two boxes with customer textures which are iphone photos of paintings.
Is it just lack of RAM ?
sanjoyp
Post by sanjoyp »
Which floor texture did you use in this photos it is exactly what I am after!
Sanjoy,
There's some kind of an upper limit to the size of texture you can use.This problem has been reported before (see this thread). The solution is to make your texture smaller.
A remark about texture size: If you make a render of 4000x3000 pixels and there's a picture on the wall (see the two pictures in your last post) then the size of the pictures on the wall is maybe 800x600 pixels. Why would you apply a texture of 2400x1800 pixels (or something similar) only to have it reduced in the final result to 800x600? It takes up a lot of processor time to calculate every pixel, but none of it shows as a better quality in the final result.
sanjoyp
Post by sanjoyp »
Good point Hans, I was using the train of thought of not removing any detail I had and using the high res imaged. Will retry.
Cheers
Sanjoy
kumax
Post by kumax »
db4tech
Not the hardness but the smoothness? I don't know how to say it, but I see some dots in the shadow and I would rather like to have it in one smooth surface. I think the thing which would solve my problem it's to render it in bigger resolution and than resize it to smaller picture. But the bigger resolution would kill my computer.. :-))
And the thing about textures.. I meant it would be nice to see some fabric texture of the sofa... for example. :)
whippetsleek
Post by whippetsleek »
Hi kumax... not sure about the shadows.. that would be puybarets or db4tech's area.. [:)] but when I want to get a fabric type texture, I used a smaller texture of between 256 x256 or 512x512, and make it the shades very distinct. Then I make the texture very small in the texture editor, like 1 inch sq. Here is an example..
It used this texture at 4x4 inches
This one is a little lighter
and used this at 1x1
And this is dark...
and used this at 6x6 inches
And those were great looking renders! [;)]
