What the Jimeny Cricket is that?!?!
That is very strange looking, and I've not seen anything like that in my limited testing using Linux. Any chance you can attach (or make available for download) an example SH3D file that demonstrates this? I want to see if this happens in Linux too. It might be something funky with the Windows compile of Yafaray included in DD3D. I've no idea how the compilation of Yafaray dll's was done in the past. I got Claude to build a CI pipeline using Github. It uses one of their windows containers, sets up an environment, and compiles the dll's for windows there. These are then bundled into the test release package. It runs some headless tests, but as I've fully dropped Windows, I don't have a way of doing eyes-on checks.
Photo-video rendering plug-in
This topic has been viewed 2478213 times and has 270 replies
Re: Photo-video rendering plug-in
Well there is a trouble on the horizon, and the sky texture IBL is not active.
The other file is about 50MB, so I threw up asimpler scene.
Thanks, guy's!
Thanks, guy's!
- Attachments
- Avant_DD3D_Q1.png (341.33 KiB) Viewed 278 times
- Avant_DD3D_native_PM.png (360.18 KiB) Viewed 278 times
And here is a SPPM render for comparison:
- Attachments
- Avant_SH3D_PVR262_SPPM.png (513.33 KiB) Viewed 274 times
Punny! But where is the test file? I can't replicate using a png. I need the saved .sh3d file. Is it failing to be attached here? If so you could use one of a multitude of file sharing services, and share the link.
Here it is.
- Attachments
- Moulding.sh3d
- (4.86 MiB) Downloaded 19 times
Yup. As I suspected, it looks like it is a Windows specific issue. This is straight from your file. I only checked it was in PM mode with the 1M caustic photons, and then hit create:
I'll try feeding it as a test file to the AI and see if it can figure it out, but troubleshooting this will be tricky.
OK, a couple of avenues are being explored. The easier one right now is some CPU/thread count issue (less likely to me). So for me and Claude to check on our side:
[Update @18:46] OK, I've got yellow pixels too on Linux, so not specific to Windows. Seems to be more related to "Direct Lighting". With a build with some debug options the renderer is switching to DL instead of PM for me, and then I see yellow pixels like you. I'd be interested if you see the same symptom if you try to manually force DL.
- What CPU is DD3D running under?
- Core/threading count?
- Is it virtualised in any way? i.e. running under VirtualBox.
I rendered the scene in DD3D with Direct lighting method. There were no yellow pixels and the sky texture IBL was clearly working. I see that it is not working in the render you made.
Best wishes.
Best wishes.
@Gudmhr Can you try the new test release at: https://github.com/DobryDom3D/DobryDom3 ... 4f37a656ed
After reproducing and trying a couple of variants, the short explanation is that it looks like newer compilers might be causing issues. By adding as a compile flag on the yafaray lib, it fixed the yellow pixels for me. Hopefully this also works for this Windows build (MinGW/GCC 16.2). (The original SH3D developer, Emmanuel, doesn't appear to have left details of how he built the Yafaray lib, so this might be a bit of trial and error.)
-fno-finite-math-onlyRe: Photo-video rendering plug-in
I have rendered both scenes and the yellow pixels are gone.
Well done, sjb007.
Well done, sjb007.
