Create my own 2D symbol furniture set
This topic has been viewed 10904 times and has 11 replies
Hi, I would like to make my own 2D furniture collection like in this link: https://embed-3dwarehouse-classic.sketc ... LOOR-PLAN- SYMBOL
Is there a procedure for this?
The only 2D furniture symbols I found are these:
http://www.sweethome3d.com/blog/2017/12 ... aries.html
and this is unfortunately insufficient.
Thank you
Thank you
Re: Create my own 2D symbol furniture set
In this thread dorin explains how he created his 2D symbol library.
Also read my remarks in this thread because the Furniture Library Editor now has features that avoid the need for manual editing of files.
Thank you Keet. Now, I´m able to create my own 2D furniture.
I just have a problem with window and door. Pls see the attachmet. When I create a door and add them, it looks like white squere in 2D preview.
https://drive.google.com/file/d/1L2AMlp ... sp=sharing
I'm not sure what the cause is of this. I can only guess that it is the result of the topview with sashes. Basically a 2D symbol is an image applied to the top of an invisible box. The lines for the sashes are very thin, so thin that they might get lost resulting in a white square. As I said, I'm just guessing here. Like other 2D symbols the image set as the plan icon should show in your 2D view.
Check the image, set it as the texture on the top of a normal box and see how it shows in your 2D view. What you see there is what your 2D symbol should look like. (Make sure you have set your preferences for "Room rendering in plan" to "Floor color or texture" and "Furniture icons in plan" to "Top view".)
Not sure where to set "Room rendering in plan" to "Floor color or texture" and "Furniture icons in plan" to "Top view". I can´t see it under preferences.
Pls see png with door (it's thick enought I think)
https://drive.google.com/file/d/1tYF1lc ... sp=sharing
And also printscreen from furniture editor:
https://drive.google.com/file/d/1-QD7LV ... sp=sharing
Should I setup some more options there?
Don't check the "Door or window" checkbox. It's a 2D symbol, not a door or window.
Compare the settings to other 2D symbols and make sure that besides the width and depth everything else is the same.
It's the SH3D preferences NOT the FLE preferences.
About the doors and/or windows 2D representation.
As you could see I've not made a 2D Symbol for that because the SH3D have it by default. Truth is not exactly how I want but...
So, my suggestion in this case, is to add to your library few 3D doors and widows with your custom representation of sashes.
You will have to manually edit for each one.
I've seen you've already have set
doorOrWindowWidthDepthDeformable=falseIf you will modify also other parameters like:
doorOrWindowWallThickness#16=25
doorOrWindowSashXAxis#16=2 130
doorOrWindowSashYAxis#16=25 25
doorOrWindowSashWidth#16=63.5 63.5
doorOrWindowSashStartAngle#16=0 180
doorOrWindowSashEndAngle#16=-90 270A computer program does what you tell it to do, not what you want it to do. Murphy's Law
Hi, I still can't create windows and doors correctly.
The procedure I chose is shown in this image:
https://drive.google.com/file/d/1nMadq2 ... Rj_er/view
When I add furniture to SH3D, the display doesn't work like with classic windows and doors. Can you tell me what I'm doing wrong in the furniture editor? Thank you
The planicon doesn't work for doors and windows. This could be considered a bug but I think there is a logical, technical reason for it.
You can try to display a 2D symbol on top of your window.
Unfortunately I don't understand what to do. Here are both 2D symbols, can you prepare them properly for SH3D so that they appear as windows and doors in the 2D view? Thank you very much.
https://drive.google.com/file/d/126X6Yw ... sp=sharing
