Webcomponent support in SweetHome3D JS
This topic has been viewed 11168 times and has 11 replies
jogibear9988
- Country: Deutschland
I'd like to use SweetHome3D in a webcomponent. But the viewHome function requires a element id. Would it be possible, if I use a HTMLElement as a parameter instead of a string, you use the compoent you get hand over, instead of search yourself for the component.
So it could be use inside of a webcomponent?
jogibear9988
Re: Webcomponent support in SweetHome3D JS
One of the changes needed would be this: https://github.com/node-projects/sweeth ... d72e0af8d3
jogibear9988
jogibear9988
Can I create Pull reuests? Never used sourceforge in the last years?
jogibear9988
I now also remove the "define" calls from some additional libs. Cause I use "monaco" editor in my frontend, wich is using require/define and this does not work with the libs. In these the code is only for nodejs support, but I think it is not needed there.
Best would be to switch to es6...
see commit: https://github.com/node-projects/sweeth ... 1a5cc97d57
jogibear9988
was the wrong commit, this is the correct one: https://github.com/node-projects/sweeth ... 0985781e1dOne of the changes needed would be this: https://github.com/node-projects/sweeth ... d72e0af8d3
jogibear9988
And another fix for activeElement inside shadowRoot: https://github.com/node-projects/sweeth ... 350031f992
jogibear9988
here is a sample how it could be used: https://node-projects.github.io/web-com ... home-3d%3E
jogibear9988
@Puybaret
what do you think about the changes? i would do them myself, if there is a way to create pull requests.
You can make patches and then submit them on the forum or directly to sourceforge
