there appear to be NO sizing fields for ROOMS, unlike WALLS!
you are forced to drag the dimensions manually and try to get right
this seems completely crazy.
Missing Functions: No Sizing Fields for Rooms
This topic has been viewed 2879 times and has 5 replies
Re: Missing Functions: No Sizing Fields for Rooms
If you want to enter the exact length of each side, press <enter> then type the length of each side. Nothing crazy, just read the included help!
that suggestion simply doesn't seem to work after many attempts.
and that ignoores the fact that the simple, easy, and obvious, fix is to have size fields
It's available only at Room creation time and when the plan has the focus (bordered by a blue line).
You could also try AdvancedEditing plug-in.
Don't think everything is easy and necessary because you want it!simple, easy
again, so helpful.
