3D View - how to adjust the color difference between N walls and S walls ?
This topic has been viewed 2284 times and has 4 replies
titust11
Country: Canada
Post by titust11 »
There's a huge color difference between North and South walls, in such a way that the South walls appear very washed out, they are white if you use a pale color. In order for the walls to have a little bit of color you have to select a very dark color. Should this be configurable? The way it is right now it looks to me like a bug that can be addressed
Re: 3D View - how to adjust the color difference between N walls and S walls ?
The 3D view is lightened by 3 fixed light sources, and there's no way to change them except if you change the program here.
titust11
Country: Canada
Post by titust11 »
Oui, Je comprends, mais tu ne trouve pas que les murs de couleur pale apparaissent toujours blanc?
If walls and rooms receive all the same light, you wouldn't be able to distinguish corners anymore.
However, you can also reduce the overall lighting in the 3D View modification dialog.
titust11
Country: Canada
Post by titust11 »
This worked perfectly, I guess there was too much light, Thanks
