how to prevent Sweet Home 3D adjust mm value to .001 ?
This topic has been viewed 3940 times and has 1 replies
hexidiot
Post by hexidiot »
Image Hi Sweet Home 3D members,
I just downloaded this software (portable version) and trying to draw some walls, but I notice some weird issue regarding the .001
My preferences is set using unit MM, magnetism disabled,
wall thickness to 120, height to 2500 and floor thickness to 500.
First, I draw walls, after that I pressed ESC after the all walls are closed
I modify the start and end value to reflect the actual building, then I notice, no matter how I change some value, there will be .001 prepend into it.
Could I set software to no decimal value? I just need precision to mm level.
Thank you.
Re: how to prevent Sweet Home 3D adjust mm value to .001 ?
I'll try to improve this in the next version.
