Hi all,
I'm experiencing the same issues as a lot of other people re the fatal error in the rendering system etc.
I've tried a range of workarounds including 32bit, running it with the ini file for Directx etc and have tried running it within Java etc but to no avail.
Has anyone got any other ideas - I'm desperate
Sean
Can't get SH3D to run on my new Surface Pro X
This topic has been viewed 7778 times and has 4 replies
LaundrySolutions
- Country: Australia
- Contact:
Re: Can't get SH3D to run on my new Surface Pro X
If none of the solutions proposed in the FAQ works, you could try to set [font=courier new]com.eteks.sweethome3d.j3d.useOffScreen3DView[/font] property to [font=courier new]true[/font], by writing the line in SweetHome3D.l4j.ini
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=trueEmmanuel Puybaret, Sweet Home 3D creator
LaundrySolutions
- Contact:
Thanks Emmanuel,
I give it a try and let you know how it went.
Cheers
Sean
Cheers
Sean
LaundrySolutions
- Contact:
Hi everyone,
Just an update, tried installing V7 and had the same result.
If anyone has any other ideas.....
Your Surface Pro X contains an ARM processor, not an Intel processor, right?
If it's the case, the installation program should be able to install a working 32 bit version running with DirectX, but I have no idea if it actually woks because the user arm64appcompatguy never answered about it in this thread.
