How to make transparent textures
This topic has been viewed 8144 times and has 3 replies
Hello all :-)
Does anyone have a suggestion how you can make semi-transparent textures?
I can think of several scenarios:
- Partially transparent walls: here I want to apply a texture to a wall. Where the GIF or PNG image is transparent, the wall should be transparent as well.
- Partially transparent objects: let's say I create a cube with a texture applied to one face. Where the image is transparent the cube should be transparent as well.
These images help explain what I want to achieve.
I tried some variations, but sofar without success.
Hopefully someone has good suggestions.
peefy
Re: How to make transparent textures
Post by peefy »
I am interested in how to do this as well.
Anybody any suggestions?
Thanks!
A basic search would give you many answers to accomplish this.
Depending on your system you can use one of the suggested solutions here: https://www.makeuseof.com/how-to-make-b ... ansparent/
If you only have a single image you want to convert there are many online sites where you can do easily this for free.
I always use GIMP. Basicly you add and aphachannel to the image and set the transparency to a selected color. The link I gave also explains how to remove a background for an image using different graphics programs.
Remember to save in a format that supports transparency, for example PNG. (JPG doesn't support transparency.)
captaincook
Post by captaincook »
Bonjour.
J'ai aussi découvert par hasard une possibilité de Power Point (pour ceux qui l'utilisent) et c'est très pratique.
Regardez la vidéo suivante.
https://youtu.be/zvEbOjns9Tc
J'ai testé et ça marche très bien.
Adobe Express, une application en ligne gratuite, est aussi très intéressante et très simple à utiliser.
Image initiale :
Image produite par Adobe Express :
L'arrière plan, qui apparait en blanc sur l'image, est en fait transparent.
Texture obtenue et appliquée sur la face avant d'un cube de 100*100*1 dans SWH:
Image finale en 3D dans SWH:
