Photo-video rendering plug-in
This topic has been viewed 2371730 times and has 240 replies
udornbusch
Re: Photo-video rendering plug-in
Post by udornbusch »
Brilliant, thanks. I didn't try the slider so did not see this which is - once one knows - quite a nifty way to do this; but wasn't obvious to me.
Thanks a lot!
Xlance
Post by Xlance »
Hello
A magnificent Plugin by all means !
>> I use "CameraBagPlugin" to create hundreds of Cameras Exceeding the 50 Limit, however I must select them one by one in Multi Photo Renderer" select dialogue.
Any chance to add CTRL-A (SELECT ALL) function or
SHIFT-ARROW selection ?
Much appreciated
Vic
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
enkonyito
Post by enkonyito »
PhotoVideoRendering-2.1 plug-in
  • fixed a bug in the management of the default shininessShader (SunFlow renderer)
  • management of depth of field properties (YafaRay renderer)
  • improved ambient lighting of ceiling lights (SunFlow and YafaRay renderers)
  • compatibility with version 1.4 of YafaRay plug-in
Enko
EnkoNyito
enkonyito
Post by enkonyito »
Hello
Much appreciated
Vic
Maybe in a future version after studying the feasibility.
EnkoNyito
Country: Copenhagen, Denmark
Post by Ceciliabr »
Hi Enko,
I wonder if you could give us a short explanation about how the different settings behave:
Direct lighting
Ambient occlusion
Path tracing
Photon mapping
SPPM
I like that you have now increased the sample setting from max 16 to max 100.
The SPPM setting is very useful, as you can stop it when it has reached an acceptable quality.
Thank you!
Cecilia
enkonyito
Post by enkonyito »
Hi Cecilia,
Direct lighting
Ambient occlusion
Path tracing
Photon mapping
SPPM
As the YafaRay web site is inaccessible, their team have made their docs available here.
What I can say about the settings I've implemented:
Direct lighting (direct light, hard shadow, equivalent to SunFlow [font=courier new]diffusedBounces=0[/font])
Ambient occlusion (direct light, less dark shadow with brightness dependent on time of day)
Path tracing (indirect light, editable number of bounces, caustics visible from 3 bounces)
Photon mapping (indirect light, predefined number of bounces, predefined number of photons)
SPPM (indirect light, predefined number of bounces, predefined number of photons, editable number of passes)
The number of samples per pixel for YafaRay ranges from 1 (min) to 1024 (max).
Correspondence with SunFlow:
antiAliasing 0 = 1 sample per pixel
antiAliasing 1 = 4 samples per pixel
antiAliasing 2 = 16 samples per pixel
antiAliasing 3 = 64 samples per pixel
antiAliasing 4 = 256 samples per pixel
antiAliasing 5 = 1024 samples per pixel
When the YafaRay documentation will be updated on their new web site, it may be possible to properly implement caustic photons.
Enko
EnkoNyito
enkonyito
Post by enkonyito »
Hello
Much appreciated
Vic
I was able to add the multiple selection option.
When opening the photos panel, do you prefer?
1- current behavior of the plug-in: 1st point of view selected
2- behavior identical to SH3D: all points of view selected
These will be highlighted.
Selection/deselection using the space key will not be available.
EnkoNyito
Baker0052
Post by Baker0052 »
Why is the rendering so much slower when i use the Photo-Video Plugin insted the yafaray plugin?
enkonyito
Post by enkonyito »
The YafaRayRendering plug-in uses a standard configuration just like the SunFlow rendering engine in the 'Create photo' panel.
The PhotoVideoRendering plug-in uses an advanced configuration to maximize the properties of rendering engines (SunFlow, YafaRay).
EnkoNyito
Magokelvin
Post by Magokelvin »
dear team... I am not posting so much in this forum... I am really an amateour of SH3D, for my porpuses I reached a good level of satisfaction in rendering. I was excited to read all about thsse rendering new features..but I have a question...
when rendering with the menu optio create photo with yafaray I obtain a bright result (don't know how to post a photo here)
when using the new 2.1 plug in...all of a sudden it becomes all dark?
where do I make mistake?
