Photo-video rendering plug-in
This topic has been viewed 2374329 times and has 240 replies
- bdfd
Re: Photo-video rendering plug-in
Try this :
Launch a rendering with version 1.9 by night (01:00 AM) with a night texture and the yarafay method... SH3D will crash quicky !!! [:D]
Good search.
Try this :
Good search.
As you can see here, I have no rendering issues with the textures and sky lighting enabled at night.Hi,
Try this :
Good search.
From your other post, the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
EnkoNyito
- bdfd
Yes, I arrived at the same conclusion but which one ?... the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
Strange, it's OK in day light and no in night time ???
Never see before this in 10 years of SH3D...
All other projects are OK. [;)]
EnkoNyito
Thanks enkonyito! Version 2.0a works like a charm! [:)]
Perfect!
Thank You!
Cecilia
Thank You!
Cecilia
Hello All,
Is there any way to do rendering on GPU ?
Thank you.
Thank you.
Hi Atefth,Hello All,
Thank you.
The rendering engines currently available (SunFlow and YafaRay) do not allow GPU rendering.
Enko
EnkoNyito
udornbusch
This sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options.
I have downloaded and installed "PhotoVideoRendering2.0a.zip" and also tried "YafaryRendering 1.3.2" but in both cases the window that opens for photos shows just the space for the photo and the 'width' and 'quality' lines and the buttons to 'create' and 'close'. There is no options to enter the time etc.
For the photovideorendering plugin there are only 3 options in the plugin drop-down (Simple photo rendering (v2.0a),grayed out multiple.. and Video rendering (v2.0a))
I am using version 6.4.2
I am a bit at a loss as to what to do. Thanks!
@udornbusch
The PhotoVideoRendering plug-in also adds to the simple photo panel: the selection of the rendering engine, its advanced settings and the activation of sky lighting.
This is where you have to make the settings that also take effect in the multiple photo panel (stored points of view) or the video panel.
Enko
SunFlow or YafaRay rendering engines can only be used at quality level 3 and 4 (best) where the date, time and lens are visible.This sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options.
Enko
EnkoNyito
