YafaRay rendering plug-in
This topic has been viewed 560308 times and has 172 replies
Re: YafaRay rendering plug-in
Ghyslain, it seems I missed one step during the build of the plug-in.
Please try the version 1.3.1 which should fix your issue.
Country: Oslo, Norway
Post by Xiste »
I just tried this version, and now the create-button works. But after the file is loaded, SH3D shuts down, leaving this message:
Process: SweetHome3D [12051]
Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Identifier: com.eteks.sweethome3d.SweetHome3D
Version: 6.3 (6300)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: SweetHome3D [12051]
User ID: 501
Date/Time: 2020-07-22 17:28:51.455 +0200
OS Version: Mac OS X 10.13.6 (17G14019)
Report Version: 12
Anonymous UUID: F590E1AE-84B7-61C6-CEA3-F11D1D8CF2C4
Time Awake Since Boot: 340000 seconds
System Integrity Protection: enabled
Crashed Thread: 140 Java: pool-10-thread-1
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000001c8
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x1c8:
__TEXT 000000010e534000-000000010e535000 [ 4K] r-x/rwx SM=COW /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Application Specific Information:
abort() called
Thread 0:: AppKit Thread Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff68f381fa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff68f37714 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff40dd7dc5 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff40dd7117 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff40dd6787 CFRunLoopRunSpecific + 487
5 com.apple.HIToolbox 0x00007fff400b6d96 RunCurrentEventLoopInMode + 286
6 com.apple.HIToolbox 0x00007fff400b6b06 ReceiveNextEventCommon + 613
7 com.apple.HIToolbox 0x00007fff400b6884 _BlockUntilNextEventMatchingListInModeWithFilter + 64
8 com.apple.AppKit 0x00007fff3e363a3b _DPSNextEvent + 2085
9 com.apple.AppKit 0x00007fff3eaf9e34 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
10 libosxapp.dylib 0x0000000a77775328 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 124
11 com.apple.AppKit 0x00007fff3e35884d -[NSApplication run] + 764
12 libosxapp.dylib 0x0000000a77774f72 +[NSApplicationAWT runAWTLoopWithApp:] + 156
13 libawt_lwawt.dylib 0x0000000a776f90bf -[AWTStarter starter:] + 905
14 com.apple.Foundation 0x00007fff42f39955 __NSThreadPerformPerform + 334
15 com.apple.CoreFoundation 0x00007fff40df4b01 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
16 com.apple.CoreFoundation 0x00007fff40eace5c __CFRunLoopDoSource0 + 108
17 com.apple.CoreFoundation 0x00007fff40dd7ab0 __CFRunLoopDoSources0 + 208
18 com.apple.CoreFoundation 0x00007fff40dd6f2d __CFRunLoopRun + 1293
19 com.apple.CoreFoundation 0x00007fff40dd6787 CFRunLoopRunSpecific + 487
20 libjli.dylib 0x000000010e6458fe CreateExecutionEnvironment + 871
21 libjli.dylib 0x000000010e6414cc JLI_Launch + 1952
22 libpackager.dylib 0x000000010e5c44c7 JavaLibrary::JavaVMCreate(unsigned long, char**) + 183
23 libpackager.dylib 0x000000010e5c1db1 JavaVirtualMachine::StartJVM() + 3457
24 libpackager.dylib 0x000000010e5c0f60 RunVM() + 16
25 libpackager.dylib 0x000000010e5ce81f start_launcher + 1791
26 com.eteks.sweethome3d.SweetHome3D 0x000000010e534cd9 main + 217
27 com.eteks.sweethome3d.SweetHome3D 0x000000010e534bf4 start + 52
pling
Country: Nederland
Post by pling »
This plug-in is awesome! Can I somehow use it for video too?
enkonyito
Post by enkonyito »
Does this version incorporate the new source code of YafaRay?
EnkoNyito
GhyslainB
Post by GhyslainB »
Thank you Emmanuel for your prompt reply!
I've now tried this new 1.3.1 version. However, another issue seems to have arisen and leads to a crash.
First trying the plugin with the jar version of the app and one of my projects. Upon launching the Create photo with Yafaray render, there is first a series of library reference error messages in the console:
dlerror: dlopen(/Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6000-90938268-2b68-4125-a6c0-b417f8f85adb/dll4459707302376552544tmp/yafaray-plugins/libphotonmap.dylib, 2): Library not loaded: /usr/local/opt/boost/lib/libboost_system.dylib
  Referenced from: /Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6000-90938268-2b68-4125-a6c0-b417f8f85adb/dll4459707302376552544tmp/yafaray-plugins/libphotonmap.dylib
  Reason: image not found
dlerror: dlopen(/Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6000-90938268-2b68-4125-a6c0-b417f8f85adb/dll4459707302376552544tmp/yafaray-plugins/libspotlight.dylib, 2): Library not loaded: /usr/local/opt/boost/lib/libboost_filesystem.dylib
  Referenced from: /Users/Ghyslain/Library/Application Support/eTeks/Sweet Home 3D/work/6000-90938268-2b68-4125-a6c0-b417f8f85adb/dll4459707302376552544tmp/yafaray-plugins/libspotlight.dylib
Etc., etc. (I won't copy all the logs here because it would fill out the forum, but I can send them to you in full if needed.)
Then, after some crunching (with medium-high CPU utilization), the application exits with this error:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x000000018df57b7d, pid=9787, tid=0x0000000000027b67
# JRE version: Java(TM) SE Runtime Environment (8.0_201-b09) (build 1.8.0_201-b09)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.201-b09 mixed mode bsd-amd64 compressed oops)
# Problematic frame:
# C  [libyafaray_v3_core.dylib+0x60b7d]  yafaray::imageFilm_t::setProgressBar(yafaray::progressBar_t*)+0xd
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /Users/Ghyslain/hs_err_pid9787.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
The referenced log file begins with the following:
---------------  T H R E A D  ---------------
Current thread (0x00007fdfc00a6000):  JavaThread "pool-11-thread-1" [_thread_in_native, id=162663, stack(0x00007000075e9000,0x00007000076e9000)]
siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x00000000000001c8
Stack: [0x00007000075e9000,0x00007000076e9000],  sp=0x00007000076e8410,  free space=1021k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [libyafarayjni.dylib+0x683e]  Java_com_eteks_sweethome3d_plugin_yafarayrendering_YafarayRenderer_render+0x2ce
j  com.eteks.sweethome3d.plugin.yafarayrendering.YafarayRenderer.render(Lcom/eteks/sweethome3d/plugin/yafarayrendering/YafarayRenderer$ImageOutput;Ljava/util/Map;)V+0
j  com.eteks.sweethome3d.plugin.yafarayrendering.YafarayRenderer.render(Ljava/awt/image/BufferedImage;Lcom/eteks/sweethome3d/model/Camera;Ljava/awt/image/ImageObserver;)V+1493
j  com.eteks.sweethome3d.plugin.yafarayrendering.YafarayPhotoPanel.computePhoto(Lcom/eteks/sweethome3d/model/Home;)V+164
j  com.eteks.sweethome3d.plugin.yafarayrendering.YafarayPhotoPanel.access$1400(Lcom/eteks/sweethome3d/plugin/yafarayrendering/YafarayPhotoPanel;Lcom/eteks/sweethome3d/model/Home;)V+2
j  com.eteks.sweethome3d.plugin.yafarayrendering.YafarayPhotoPanel$17.run()V+8
j  java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+95
j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
V  [libjvm.dylib+0x2f0bea]  JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*)+0x6ae
V  [libjvm.dylib+0x2f138e]  JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*)+0x164
V  [libjvm.dylib+0x2f153a]  JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*)+0x4a
V  [libjvm.dylib+0x34be29]  thread_entry(JavaThread*, Thread*)+0x7c
V  [libjvm.dylib+0x570c33]  JavaThread::thread_main_inner()+0x9b
V  [libjvm.dylib+0x57232e]  JavaThread::run()+0x1c2
V  [libjvm.dylib+0x48f3ca]  java_start(Thread*)+0xf6
C  [libsystem_pthread.dylib+0x3661]  _pthread_body+0x154
C  [libsystem_pthread.dylib+0x350d]  _pthread_body+0x0
C  [libsystem_pthread.dylib+0x2bf9]  thread_start+0xd
C  0x0000000000000000
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
I've also tried with the App Store version of SH3D (and a demo file), and it leads to the same behaviour, with the following System crash report:
Crashed Thread:        100  Java: pool-10-thread-1
    __TEXT                 000000010d3b3000-000000010d3b4000 [    4K] r-x/rwx SM=COW  /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
abort() called
0   libsystem_kernel.dylib        	0x00007fff512ba20a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff512b9724 mach_msg + 60
2   com.apple.CoreFoundation      	0x00007fff29186845 __CFRunLoopServiceMachPort + 341
3   com.apple.CoreFoundation      	0x00007fff29185b97 __CFRunLoopRun + 1783
4   com.apple.CoreFoundation      	0x00007fff29185207 CFRunLoopRunSpecific + 487
5   com.apple.HIToolbox           	0x00007fff28465d96 RunCurrentEventLoopInMode + 286
6   com.apple.HIToolbox           	0x00007fff28465b06 ReceiveNextEventCommon + 613
7   com.apple.HIToolbox           	0x00007fff28465884 _BlockUntilNextEventMatchingListInModeWithFilter + 64
8   com.apple.AppKit              	0x00007fff26715a73 _DPSNextEvent + 2085
9   com.apple.AppKit              	0x00007fff26eabe34 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
10  libosxapp.dylib               	0x000000012800c328 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 124
11  com.apple.AppKit              	0x00007fff2670a885 -[NSApplication run] + 764
12  libosxapp.dylib               	0x000000012800bf72 +[NSApplicationAWT runAWTLoopWithApp:] + 156
13  libawt_lwawt.dylib            	0x0000000127f900bf -[AWTStarter starter:] + 905
14  com.apple.Foundation          	0x00007fff2b2e50b5 __NSThreadPerformPerform + 334
15  com.apple.CoreFoundation      	0x00007fff291a3581 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
16  com.apple.CoreFoundation      	0x00007fff2925b8ac __CFRunLoopDoSource0 + 108
17  com.apple.CoreFoundation      	0x00007fff29186530 __CFRunLoopDoSources0 + 208
18  com.apple.CoreFoundation      	0x00007fff291859ad __CFRunLoopRun + 1293
19  com.apple.CoreFoundation      	0x00007fff29185207 CFRunLoopRunSpecific + 487
20  libjli.dylib                  	0x000000010d49d8fe CreateExecutionEnvironment + 871
21  libjli.dylib                  	0x000000010d4994cc JLI_Launch + 1952
22  libpackager.dylib             	0x000000010d45d4c7 JavaLibrary::JavaVMCreate(unsigned long, char**) + 183
23  libpackager.dylib             	0x000000010d45adb1 JavaVirtualMachine::StartJVM() + 3457
24  libpackager.dylib             	0x000000010d459f60 RunVM() + 16
25  libpackager.dylib             	0x000000010d46781f start_launcher + 1791
26  com.eteks.sweethome3d.SweetHome3D	0x000000010d3b3cd9 main + 217
27  com.eteks.sweethome3d.SweetHome3D	0x000000010d3b3bf4 start + 52
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff512c3d82 __semwait_signal + 10
1   libsystem_pthread.dylib       	0x00007fff5148f824 _pthread_join + 626
2   libjli.dylib                  	0x000000010d49cebb ContinueInNewThread0 + 102
3   libjli.dylib                  	0x000000010d49a378 ContinueInNewThread + 201
4   libjli.dylib                  	0x000000010d49cc1b JVMInit + 363
5   libjli.dylib                  	0x000000010d49a0f6 JLI_Launch + 5066
6   libpackager.dylib             	0x000000010d45d4c7 JavaLibrary::JavaVMCreate(unsigned long, char**) + 183
7   libpackager.dylib             	0x000000010d45adb1 JavaVirtualMachine::StartJVM() + 3457
8   libpackager.dylib             	0x000000010d459f60 RunVM() + 16
9   libpackager.dylib             	0x000000010d46781f start_launcher + 1791
10  com.eteks.sweethome3d.SweetHome3D	0x000000010d3b3cd9 main + 217
11  libjli.dylib                  	0x000000010d49d590 apple_main + 92
12  libsystem_pthread.dylib       	0x00007fff5148b661 _pthread_body + 340
13  libsystem_pthread.dylib       	0x00007fff5148b50d _pthread_start + 377
14  libsystem_pthread.dylib       	0x00007fff5148abf9 thread_start + 13
Hopefully, this might help you figure out what is going on. Thanks!
GhyslainB
Post by GhyslainB »
P.S. to my last post, I've tried version 1.2 of the plugin and it works fine, so my config probably isn't the root cause for the 1.3.1 crash.
Cheers.
Ghyslain, it seems I missed more than one step during the build of the plug-in 1.3. [:(]
Please try the version 1.3.2 which should fix at least the "Library not loaded" errors you reported. Not sure if the other errors are bound to this first ones. I hope so.
No, versions 1.3.1 and 1.3.2 fixes only wrong internal links in .dylib libraries for macOS. The recent changes in YafaRay will be incorporated to YafaRay rendering plug-in later. It's not urgent because the change log lists only issues on some features not used in the plug-in.
See PhotoVideoRendering plug-in cited in plug-ins page.
GhyslainB
Post by GhyslainB »
Emmanuel, third time’s the charm! Version 1.3.2 works for me. Thanks for the fix [:)]
Ghyslain, thanks for your feedback.
Ceciliabr, Xiste, could you try this new version too?
Country: Copenhagen, Denmark
Post by Ceciliabr »
YES! YES! YES!
SH3D 6.4 and YafaRay 1.3.2 works perfectly!
Took three minutes to load, but rendered in six – and this is a HUGE file!
I salute you!
https://www.youtube.com/watch?reload=9&v=LAdxhHz6Tu4
Cecilia [;)]
