Hello!
What a great programm this is! I have two questions about the same problem.
Is it possible to put in the degree angle for a wall? (I know i can type beginhight and endhight though, but still then I don't know what angle it is). This I would like to be able to see aswell. Is this possible too?
The otherway round would be very handy aswell: The max hight is: 5,5 m and the length of the wall is 3 m. The programm wil adjust the wall like this automatically. Is this possible?
thanks in advance
angle wall
This topic has been viewed 5099 times and has 4 replies
hebeentuin
- Country: Netherlands
Re: angle wall
I've found part of the answer,
There is also an option where you can adjust starting hight of the wall and ending hight thus creating an angle.
I'm still looking for a way to make the angle visible in the drawing and to somway insert the angle I want and that the walls hight and distance will adjust automatically. Is this possible?
Re: angle wall
Click to mark the first point of your wall,
On the keyboard hit Enter
In the little window that pops up you can enter length, thickness and angle.
There is no feature to add a "dimension" that indicates the angle, but you could use manually inserted text.
hebeentuin
Re: angle wall
I'm gonna have a look. I think I know what you refer to but that turns the wall sideways I think. Maybe I'm using the wrong word 'angle', and it should be slope..I'm not sure but I'm gonna try it again. I'll let you know if I figure it out or not. thankyou.
Re: angle wall
If you need a wall that starts high, and ends low, use Modify Walls. There you can set start and end heights.
If you want a leaning wall, that is NOT perpendicular, you cannot make that. Instead use a box that you rotate.
