How do I change the angle to the wall was less than 15 degrees?
This topic has been viewed 18505 times and has 4 replies
100matolog
Re: How do I change the angle to the wall was less than 15 degrees?
If you hold down the SHIFT key while drawing a wall you can draw walls at any angle.
You can also disable Magnetism in the Preferences, but then you can't insert doors/windows anymore.
100matolog
You need to hold down ALT as of version 6.1.2, not shift.
The magnetism shortcut changed to Alt (cmd under macOS) with version 4.0 in 2013, after this thread was started. Thanks for reporting the change even a long time after.
