i´m new here but i didn´t found anything in the Forum. Is there a possibillity to export my fles as a dxf or dwg file???
Hope there will be some solution.
Thx & best regards
Andreas
Export 2D to dxf or dwg
This topic has been viewed 58591 times and has 4 replies
Re: Export 2D to dxf or dwg
For this kind of task I use this way:
1. Plan->Export to SVG format...
2. Open the svg file with Inkscape
3. From Inkscape File->Save as... choose .dxf format.
4. Then You could open in LibreCAD or AutoCAD.
You will don't have all the items but could be useful for start.
thanks for your help. But it doesn´t really work on my mac. So i tried the tool CAD Exchanger, which worked good for me...
thanks for the tip [:)]
You can also try the plugin DXFexport
