I need to import models from autocad so I supose that I need to transform them to .3ds or .obj files.
Could you recommend me any tool for this task?
I have seen that Autodesk 3Ds Max can transform from dxf to 3ds but I haven't any license to do this.
Thanks in advance. Diego
How to import autocad .dxf or .dwg files to .obj
This topic has been viewed 44822 times and has 5 replies
Re: How to import autocad .dxf or .dwg files to .obj
Thanks a lot for your help,
Problem is that these programs only convert from dxf or dwg to an image format (not to a obj file or 3ds necessary to work with sweethome).
Did you find a solution to this? I mean it looks like a nice app but I have my house all drawn up in DXF files and would like to import them as the baseplan, not recreate ...
- dorin
For blueprint You need to import a png file.
I use this way to solve it:
AutoCAD(dxf/dwg)->export as pdf -> convert in png with GIMP.
Then import as background in SH3D.
Of course I must redraw all wall & etc.
thanks for sharing.
