Issue with groupings and levels
This topic has been viewed 2746 times and has 2 replies
deco0224
Country: Ireland
Post by deco0224 »
Hi there,
I have modeled my 3 story house seperated on 3 levels.
Each level looks perfect with its own furniture etc.
But then when group the furniture I have problems. I am grouping all the furniture on the same level together, eg all level 0 furniture is in a group called 'Level 0 Furniture and the same with the other floors. I have also grouped all the level 0 electrical together into groups etc.
The problem I am facing is some of the furniture from level 0 appears on level 1. When I ungroup the furniture, it displays fine again.
I have selected each piece of furniture and checked to make sure it is on the correct level. I have set up the right levels with the correct elevations and none of the furniture on level 0 is taller than the ceiling height. I have set each room up using the Add room feature and each room has a ceiling and a floor.
I would greatly appreciate any help on this - thank you.
Country: UK
Re: Issue with groupings and levels
Post by Mike53 »
Check you have not included stairs in your groups, they are on 2 levels. Light fittings can also be an issue if the elevation + depth takes them above the ceiling.
Gildaniel
Country: Russia
Post by Gildaniel »
Try before grouping elevate your level extrimely high (10m) then, group objects and lift back
High furniture can be seen and selectable through levels
