First, congrats on the top notch program !!! It is amazing !!!
I just have a small issue with a 2-floor structure (level 0 and level 1) : the 3D view for the level 1 does not work properly : I cannot see only this floor in 3D as I get the view for both levels. Using the "display selected level" or "display all levels" does not change anything : I get only the "all levels" display. If it helps, I am on the french version and switching language to english, does not seem to update the "levels" names as they remain called "niveaux" : would that be the issue ?
Thanks for any help !
Issue with levels
This topic has been viewed 5413 times and has 1 replies
Re: Issue with levels
Sweet Home 3D doesn't allow to hide levels under an other one. Display selected level real name should be Display selected level and levels below. The only workaround would be to edit this level in a separate document.
As you are free to name a level as you wish by double-clinking on its level tab, I chose not to rename levels automatically when you change the language in the preferences.I am on the french version and switching language to english, does not seem to update the "levels" names as they remain called "niveaux"
Users browsing this forum: DuckDuckGo [Bot], Semrush [Bot]
