Two level with the same elevation: some rooms on upper level are transparent
This topic has been viewed 10818 times and has 22 replies
Re: Two level with the same elevation: some rooms on upper level are transparent
I think I understand what you mean.
Actually, all rooms are half transparent, but when you draw a room (like the 4.27 m² one, the 1.77 m² one and the other small ones) superimposed on another larger one (like the large green one), the small rooms get less transparent.
Gildaniel
Country: Russia
Post by Gildaniel »
Sorry, I haven't understood your explanation, what the logic is here, why one room transparent, another not? How to get superimposed rooms always nontransparent?
I see there is a trick to get nontransparent room, superimposed on lager one - at least one corner of the room should be drown outside wall contour - now room became nontransparent, then you can correct it as you wish and it retain colour. It works, but then I cannot use doubleclick for fast creation room inside walls, it was very comfortable, rapid drawing is important for me :(
alaX
Country: Poland
Post by alaX »
I tested your case and this is my solution:
  • Select "Create walls" - double click on the grass,
  • delete grass,
  • select "Create rooms" - double click somewhere inside these new walls,
  • delete walls (if you don't need a fence)
  • cut and paste the house ( in order to select the house covered now by the new grass make level 0 unviewable or move aside the grass or select all and deselect the grass )
Gildaniel
Country: Russia
Post by Gildaniel »
  • delete grass,
Thank you, it works! Good idea to redraw grass using walls!
alaX
Country: Poland
Post by alaX »
still, it doesn't look good on rendered photo
Gildaniel
Country: Russia
Post by Gildaniel »
Yes, same problem on 3d.
May there is some other solutions?
Gildaniel
Country: Russia
Post by Gildaniel »
Difficult to say from your screen captures. It could be a bug or simply a misunderstanding of rooms and levels. Could you post a simpler example?
Dear Emmanuel, could you please check this problem? It steel exist, and there is no good solution to avoid
I tried to fix the problem shown in the 3D view of your last image many times, and unfortunately there are still a few cases where it doesn't work. It's a problem about cutting the ground with rooms to avoid them to overlap the ground. Moving the corners of the rooms may resolve the issue.
alaX
Country: Poland
Post by alaX »
Use background image with grass texture and make sure you have selected "Background image visible in 3D view"
Bubblobill
Country: Australia
Post by Bubblobill »
This seems to be a case of two planes fighting over the z-index. Would changing the floor thickness of the grass level to be lower than the house level floor thickness result in the room's floor being drawn above the grass?
