Two level with the same elevation: some rooms on upper level are transparent
This topic has been viewed 11282 times and has 22 replies
Gildaniel
Country: Russia
Post by Gildaniel »
Hello!
I often use two levels with the same elevation, first as ground (grass on the picture), second is house first floor, to show house placing.
When both levels are on, somehow some of rooms of floor level became transparent on the plan. If I cut and paste rooms I have more "solid" rooms, but couple of them are still transparent.
How to avoid transparent rooms?
Before cut and place:
After cut and place some room still transparent:
Re: Two level with the same elevation: some rooms on upper level are transparent
Difficult to say from your screen captures. It could be a bug or simply a misunderstanding of rooms and levels. Could you post a simpler example?
Gildaniel
Country: Russia
Post by Gildaniel »
Of course, here you are http://regard-house.ru/3dplan/fv/transpareny.sh3d
Thank you for your help!
Daniel
Gildaniel
Country: Russia
Post by Gildaniel »
There is an exapmle attached, could you please check?
Gildaniel
Country: Russia
Post by Gildaniel »
Please [:-/]
When I click the link to download the file, I get a 404 message. I can't read it, but it should mean the file/page doesn't exist (anymore).
alaX
Country: Poland
Post by alaX »
Without downloading your file i can suggest: either draw "grass" room AROUND the house (NOT UNDER it), or raise the house level a little bit so it's no longer at the same elevation as grass level.
Gildaniel
Country: Russia
Post by Gildaniel »
Sorry, there was a mistake in the link
http://regard-house.ru/3dplan/fv/transparency.sh3d
is correct one
Gildaniel
Country: Russia
Post by Gildaniel »
Usually I use sattelite or cadastre map to find needed land area, screenshot and import this picture as a background image, scale it to real dimension and draw "grassed" room over it, to discuss where to place building, moving it around.
It's possible to draw room around house, as a last resort, thank you.
If house elevation will be hier then ground level, no grass will be seen on the plan at all.
Gildaniel
Country: Russia
Post by Gildaniel »
I found some regularity in this bug.
If you draw room in closed wall area - it is transparent. If you draw in non-closed area - it normal
