Is there a known issue when opening a second file / flat?
3D view works, but the 2D screen shows red squares instead of the common furnitures view.
see https://we.tl/t-grkGO5Ssaz
Rendering Issue if open more than one flat
This topic has been viewed 5021 times and has 5 replies
- bdfd
Re: Rendering Issue if open more than one flat
And ??? [:D]
What is the configuration of your PC ?
This sounds like a memory problem. What memory use is indicated in the About dialog? Did you try to increase the max memory if possible?
OK, I created such a ini file with 1000M (tried 1200M, but SH3D doesn't start anymore) and SH3D uses 0,5-0,6 GB of 0,9 GB - red squares
Is 900 MB the maximum?
My PC is a HP spectre with 16 GB RAM and two 4k Monitors (1 generic, 1 via DisplayLink) @Win10 64bit
Run the installer again and select the 64 bit architecture in the screen that lets you choose the installation folder.
THX, that helps. Now I have V6.1.2 and this installer has an option to choose between 32 and 64 bit. With 64bit the rendering works fine.
