Re: Single Glass Door
This topic has been viewed 9051 times and has 8 replies
stef.salmon
Country: UK
Post by stef.salmon »
Is there a single glass door in any of the libraries?
I can't seem to find anything!
stef.salmon
Country: UK
I guess there are no glass doors?!
Did you look here ?
stef.salmon
Country: UK
No I didn't, thanks Hans.
stef.salmon
Country: UK
I have downloaded this door:
https://3dwarehouse.sketchup.com/model/ ... glass-door
Is there a way of getting it to appear 45 degrees open?
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
It's a frameless door, so turn it for 45° and place it where it should be...
If the cutout in the wall does not fit, place a single frame from the lib where the cutout should be.
Pascal
stef.salmon
Country: UK
Thanks UbuntuBirdy.
I tried this and it did work...sort of. Why doesn't the door snap to the wall like the doors from the library?
Isn't there an easier way of using an existing door from the library and then changing the material to glass?
Maybe because the door/window option was not selected on import(?)
Anyway, a glass door is a good model for testing hinges, frosted glass, cutout and 2D door-opening indicators..
Here is a quick example in SF 3d models 508
glass_door_hinged_cutout_plain.sh3d
stef.salmon
Country: UK
Yes it was a problem with the way I'd imported it, thanks.
