Wall capy and paste
This topic has been viewed 2090 times and has 5 replies
esse2003
Country: Italy
Wall capy and paste
Post by esse2003 »
Hi all. Is possible to make a copy and paste of walls already built in another project? I need them with a certain angle, that’s the problem. Is that possible? I don’t want to import as an obj because then i cannot edit anymore. Thanks again!
Re: Wall capy and paste
You can select the walls you want to copy, choose Edit > Copy menu item, open the other project, click in its plan and choose Edit > Paste menu item.
esse2003
Country: Italy
Post by esse2003 »
Yes, that’s correct but then i cannot give to the walls an angle? Right?
Maybe you could try AdvancedEditing plugin?
esse2003
Country: Italy
Post by esse2003 »
I tried but you cannot do nothing with walls. There is not a function ti rotate walls unfortunately. Thanks anyway..
I just tried and you can rotate walls with the plugin. Please try again.
