Sweet Home 3D 5.7
This topic has been viewed 84300 times and has 18 replies
Country: Copenhagen, Denmark
Re: Sweet Home 3D 5.7
Post by Ceciliabr »
<string>-Xmx8g</string>
serinter
Country: Brazil
Post by serinter »
Java Web Start works great !
the problem I mean, is in The installer version! Windows 8.1
When I mean "nothing happens", is because, i go to "save" window, write the name, and click in SAVE, the "save window" close, but the file didnt save,!
serinter
Country: Brazil
Post by serinter »
How can I insert older library to the Java Web version ?
Because this version works normal for me ! but with limited library
Country: Oslo, Norway
Post by Xiste »
@Xiste
Did you solve this? In that case, please tell me how.
Sorry.
I got the same error as you. But, as you say, this version is unimportant, so I didn't put a lot of effort into fixing it.
x
live
Post by live »
OS win10 64bits
After 5.4, every version incl 5.7 on launch:
"Sweet Home 3D doit quitter maintenant à cause d'une erreur fatale dans son système de rendu 3D. Mettez à jour les drivers DirectX/OpenGL de la carte video de votre ordinateur"
Live, try the suggestion about [font=courier new]dxwebsetup.exe[/font] in this subject,
and if it doesn't work, then try the parameters [font=courier new]/j3d.version=1.5.2 /os.arch=x86[/font] added to the installer and described here.
Xiste, Ceciliabr, maybe High Sierra does not accept to change [font=courier new]Info.plist[/font] anymore. Strange that it worked on my side...
Post by Ceciliabr »
Xiste, Ceciliabr, maybe High Sierra does not accept to change Info.plist anymore. Strange that it worked on my side...
Yes, that is indeed very strange. I have tried both ways of editing the info.plist on several machines, and I get the same error.
This obviously has nothing to do with OSX, since I still have no problems editing the info.plist in v 5.0 without getting any error message.
Maybe some security measures have been included in the newer versions of SH3D, something that's preventing any attempt to alter the original?
cec
I found how to reproduce your issue: I downloaded Sweet Home 3D DMG, copied the application on my hard disk, changed the Info.plist file then launched the program. But if you launch the program at least once before updating the Info.plist file, the error won't happen.
Hope this will work for you [:)]
Post by Xiste »
GREAT!
Thank you!
