How to create wall & floor tiles with different grout thickness
This topic has been viewed 9712 times and has 8 replies
peterweaver
Country: UK
Post by peterweaver »
Hi there,
Could you let me know, if is it possible to create a wall and a floor tiles with any decor etc?
Cheers
Re: How to create wall & floor tiles with different grout thickness
Yes. It all depends on the texture file you use. For a simple tiled wall, you can use one .png/.gif/.jpg of (64×64 is usually a good size). Add the grout as a border on your image, just as thick as you like. In the examples you got before, you will see multiple tiles (just to create an illusion of the tiles not being exactly the same). But one tile is usually enough. ok
peterweaver
Country: UK
Thanks for your reply.
For example-if I want to create a tile 300mmx300mm and a grout 3mm.How can I do it step by step?Also I would like to use my own texture?Is it any online/youtube video?
Thanks for your help
Put a test tile in SF 346. You need a very simple file with border, scaled to 300×300. But to get it right, you need may to edit, create a larger tile pattern with some sort of graphics editor to get what you want. One approach, step by step, is the link to the manual I posted earlier: How to create personalized textures for Sweet Home 3D (PDF) by Ouais, translated by Hansmex. Not my preferred way, but it is a good start to get what you want. Check the other examples in SF 346 to see how it can work. ok
tile_test.sh3d
peterweaver
Country: UK
Thanks a lot. I need to learn your instructions.
I see how it goes.
Regards
peterweaver
Country: UK
Are there any other ideas to make a tiles?I have been trying to use your attachment and I can not.
Post by bdfd »
You can take a thin box with its texture to apply it on a wall.
The advantage is the choiced size.
There is an example HERE the credance over the sik (last picture on thread "Cubic houses - part 2").
Regards.
peterweaver
Country: UK
I have seen your cubic houses.
Where can I download those kitchen cabinets/drawer,furniture etc?
Cheers.
Regards
Post by bdfd »
All furnitures are standard in sh3d.
see category named 'kitchen'.
