sad High priority Different Wall Thickness (start & end)
This topic has been viewed 8531 times and has 4 replies
Chevinster
Country: Matara, Sri Lanka
Post by Chevinster »
Sweet Home 3D is a great software & thanks.
I was trying to make a pillar Type water building That start with a 10" thickness & middle of it change to 4" & again it end with 15" thickness but I was unable to do that. I managed to make a cylinder type wall since I couldn't find an option to change the wall thickness in start & end.
If there is a way to do that please advice step by step how to proceed.
If you don't understand what i want to do I have attached 2 images.
I think if you can add an option to change the the wall thickness in begging of wall & end of wall differently you are making this software open for new creative designs.
Thanks in advance
Chevinster
Image Image
Re: Different Wall Thickness (start & end)
Would two curved walls running next to each other - an inner and an outer wall - do the trick?
Chevinster
ya can try but not the best thing or wont give the smooth look.
harbinger
Country: Clearwater, FL, US
Post by harbinger »
You'll probably have to do what i was forced to do: model an object in a 3rd party CAD or 3D modeling application & import it into the furniture library. In that case you'll have a lot more control -- you just have to save it in a format that SH3D can handle (i HIGHLY recommend OBJ with an accompanying MAT file).
Our dear programmer must keep a balance between ease of use and user "customizability." So i don't know if the ability to dictate exact wall dimensions at all points would be viable with his overall vision for SH3D.
I would however would love walls that fade to different thicknesses...
As the attached example shows you can play with multiple walls with a different thickness to get something that would look like you want a little. But it requires some big efforts to draw it, and I would keep that trick only for this simpler case.
WallWithVariousThickness.sh3d
(3.2 KiB) Downloaded 450945 times
