view problem
This topic has been viewed 4434 times and has 6 replies
view problem
How can I set view to deafult? After moving furniture my screen went white in 2d and 3d view. Couldnt see nothing from my project
- bdfd
Re: view problem
Perhaps a point of view too near of a wall ?
Try to update it...
Change between aerial and virtual mode...
Try to update it...
Re: view problem
Ui looks very weird after that happend looks like bugged.
https://ibb.co/e9tFy5
- bdfd
Re: view problem
Right click and choose 'see all levels'...
Re: view problem
It looks like a bug that happens from time to time in multi level homes.
Please [url=mailto:[email protected]]send me[/url] your file, I'll fix it.
Re: view problem
It wasnt advanced project so I made new one and save every time after changes. Problem happend when I put furnitures like windows and drag them at the edge of 2d view window. "see all levels" option doesnt help. I have sent the file to puybaret.
Re: view problem
Thanks for the file which helped me to reproduce your issue. [:)]
The problem comes from the small walls you drew in some corners as shown in the following image:
As you can see, it creates some walls that may have a null length side, and a part of the program that measures the distance between an object and wall side failed for a side equal to zero.
I fixed this bug and the correction will be available in the next version.
Meanwhile, you should avoid these small walls and connect directly walls while drawing them.
