Hi
I installed sh3d 7.5 on my new Tuxedo-Laptop (TuxedoOS/Kubuntu)
I have already sh3d 7.5 on my desktop (Kubuntu KDE Plasma).
While I am able zooming close to my house in areal view on my Desktop, i can't do this on my new Laptop ... the view stays in a panoramic state and i cannot come closer ... (while I can do it on my desktop)
The difference may be that my kubuntu Desktop works with X11 while the Laptop has Wayland.
Is there a way to solve this ?
Brgds
Areal View Problem
This topic has been viewed 140382 times and has 19 replies
Re: Areal View Problem
[=D>]new Tuxedo-Laptop
Switch the laptop to X11?The difference may be that my kubuntu Desktop works with X11 while the Laptop has Wayland.
https://linuxconfig.org/how-to-use-x-in ... untu-22-04
Notice the warning.
I tried this, but it doesnt change ... still no zoom in areal view.
Do you have a menu option "Parallel projection" under 3D view? Maybe you have activated it which would prevent zooming.
I don't find any option like that.
Where should it be ?
It seems that the zoom is oriented at the "widest" niveau.
If I hide the surrounding - niveaus I can zoom closer.
I dont have this limitation on desktop ....
It's under the 3D view menu option but I possibly have it through one of my installed plugins (Pan3Dview?)I don't find any option like that.
With Pan3Dview installed I dont have such an option, but ...
With this plugin I can zoom in areal view, although it's a bit hard to handle. If I change sight-angle it pops back to panorama and I have to zoom again. It's also very tricky with zoom-scrolling - if you do it too fast its jumping to extreme zoom and back ....
Are you sure it's the same project? A different selected level, which levels are visible, objects over a wider area, a selected object, all of these can change the behavior of the zoom. The exact same situation should result in the same zoom behavior.It seems that the zoom is oriented at the "widest" niveau.
Have you tried scrolling with an external mouse?
Does the same happen if you have the 3Dview pane detached (separate window)?
It is the same file/project shared and updated by a nextcloud server. It Is exactly the same situation, also the external mouse is the same brand.
Seperate window makes no difference. The only difference is the machine it is running on.
