create room with exact size impossible
This topic has been viewed 21831 times and has 11 replies
Ash2k
Post by Ash2k »
I am trying to create a room which has accurate measures, but it seems, I can only generate measures on 2 mm exact measure instead of 1 mm.
My room is 1555mm long but I can only create one with 1554mm or 1556mm lenght, is there any way to make it exactly 1555 mm long ?
Re: create room with exact size impossible
Post by bdfd »
Did you try to reduce the thickness of the wall of 2 mm ?
(1 mmm for each side).
Ash2k
Post by Ash2k »
where can I do such a thing ? I did not even know, there is a wall, if I create a room, I think creating a wall is something diffrent.
Post by VeroniQ »
Did you read the user's guide ?
Ash2k
Post by Ash2k »
So I have to read all to find out, how to create a room, with a size of 1 mm more ?
Look it is a simple question, I am not unexperienced with other pretty similar tools. I only not understand, how to make my room 1555 mm long that is all.
If this program is not able to do so, then it is bullshit and I download another one, simple as my question is.
My room has no walls yet, because it does not show the exact size I want it to have.
Post by bdfd »
Your brain is strange !
A room without wall is a terrace... [:))]
But I'm agree with you about the distances 1554 or 1556 are only available, not 1555 mm. [:((]
So tell us why 1 mm is important for you ?
Wait after Manu's answer... [;)]
Ash2k
Post by Ash2k »
The room, and wall are even 2 diffrent symbols in this program.
Why 1 mm is important ?
Sry ?
This is a 3D design program, isn't it ?
It is used to make plans of rooms, and if I can't realize my room in it, it simply does not fulfill it's purpose at all.
If that room is 1mm longer or shorter, it will not fit into the other 3D Environment.
This program looks pretty good, but it is useless, I am sry, all your hard work for nothing.
It's only coold for kids.
Thx for "help" cu
and good luck
Possibility 1
To draw EXACT lengths, use this feature:
- select the Walls button
- click for first point of wall
- hit Enter
- a small window pops up where you can enter the exact length of the wall, angle and thickness
- make walls 1 mm longer than needed and set wall thickness to 1 mm
Your walls will have your exact dimensions.
Possibility 2
If you have the AdvancedEdit plug-in installed, you could also draw a room, then EditPoints to set the exact room dimensions.
- select the Room button
- draw a room that has the approximate size and shape you need
- edit the room points using Plan --> Edit Points
- double click on the room: walls will be drawn around your room
Good luck with this "kids program".
Maybe you should study the user guide and help files before drawing conclusions?
My motto in life:
If you don't know how to use a program: blame the program, not yourself!
lordthistle
Post by lordthistle »
I agree with the original poster that this functionality is a little too counter-intuitive (by far the most "difficult" among the 3D design programs I have used). I have exactly the same difficulties.
I have installed the advanced edit plugin, but I cannot find the "plan -> edit points" menu item. However, long menus are not fully visible on the screen and they do not scroll so may be the item is not visible.
You could try to create rooms first as explained in this video.
Users browsing this forum: Amazon [Bot], Bing [Bot], Semrush [Bot]
