arch on half round wall
This topic has been viewed 11109 times and has 12 replies
bugarski.nenad
does anyone know how can i make/drow arch on a half round wall? tnx
Re: arch on half round wall
After you have drawn a wall with correct endpoints, double-click (or select and Modify walls) to enter Arc extent in the wall properties. ok
bugarski.nenad
that makes a half round wall. i know that. what i want is to make arch hole in that kind of wall...
- bdfd
If I understand correctly, you want to do that ?
If yes, you can use the default object 'arch'.
if no, you must create two walls* which will export in obj format.
You import again the new object and when you see the green arrows, click on up right frame (front view) and then with the mouse and key shift click on the down green Arrow to have 90° and click enter...
You'll have your half arch, see the joined file below.
(*) First wall : standard
Second wall : same than first but 'arc extent' = 90° and joins the twice.
- Attachments
- Half arch.obj
- (12.28 KiB) Downloaded 10561 times
If you want to put the arch IN the curved wall, then i think you can create your wall, give it an arc, then position an arch , from the library, but turn the magnetism OFF, make the arch as big as is needed to create the opening.
Tried it and failed sorry, the opening that is created is rectangular, i will have a rethink.
I managed to make some thing that might do you, or at least give you an idea how you might achieve what you desire, here is a link to a sh3d file.
Nice attempt Mike. Of course, this workaround will work more or less well, according to the width of the arch and the curve of the wall...
I know EP, but its all i could think of [:(]
