I'm running on Ubuntu, every time I try to install a plugin I get the following error pop-up from sh3d.
Running command: /usr/bin/sweethome3d ExportToHTML5-1.1.sh3p
Getting "Can't import plug-in"
pop up in dialogue box.
I've also tried manually moving the extract into ~/.eteks/sweethome3d/plugins but it doesn't seem to recognise it.
Thanks.
Trouble installing plugins..
This topic has been viewed 9566 times and has 3 replies
stevellion
- Country: United Kingdom
Re: Trouble installing plugins..
DO this
- CTRL H (this shows hidden directories)
- go to /.eteks/SweetHome/plugins (or something similar)
- if "plugins" doesn't exist, create it
- copy the plugin(s) to that directory
- (re)start SH3D
- (re)start SH3D
stevellion
Thanks hansmex.. I'd tried all that stuff already and copying into a new directory.
In the end it was something really silly.
Even though I was in the directory holding the sh3p file, I needed to specify explicitly the directory, not just relative.
ie.
/usr/bin/sweethome3d /home/joebloggs/downloads/plugin.sh3d
It must be something in the script that uses it for install.
ie.
Maybe the program doesn't have the rights to copy in the target directory. To be sure where this folder is, import a furniture library and if it works, search on your disk the [font=courier new]furniture[/font] folder where it was copied. The [font=courier new]plugins[/font] folder should be a sibling folder of that [font=courier new]furniture[/font] folder.
