I've managed to make a bar counter for a Bar I'm designing for a story - (out of a wall), but I want to do further customization to it but apparently I cannot 'stack' walls at all.
I wanted to do a box wall, then a flat 'counter' board on top of that.
I dunno if there is anything I can do to further customize that wall. Any Wall object HAS to start from the bottom, apparently.
Help? Or do I just export the Wall to Blender, and try to make a counter OBJ file?
Bar Counter Object?
This topic has been viewed 7413 times and has 3 replies
Re: Bar Counter Object?
As you say, walls cannot be 'stacked'. But other objects can, such as a box. Not knowing exactly what you want to do, you could export wall elements as .obj files, and re-import them, then you would have the 'walls' as stackable objects.
Or you could use the Shape Generator plug-in or other software (such as Blender, AoI etc).
It is, btw, possible to make various cut-outs in a wall to, see the blog post
How to create a hole at the bottom of a wall
Right. Thanks for the tips
I'll figure something out.
Actually, I'm fine with the way I have the 'wall' set up as a bar. The Plan of the bar isn't really needing to be ultra detailed - just enough so I know where things are, more or less.
