Progress and time of photo rendering
This topic has been viewed 45073 times and has 36 replies
alaX
Country: Poland
Re: Progress and time of photo rendering (Create photo with renderer plug-in)
Post by alaX »
enkonyito,
Your plug-in is great but I encountered some issues.
1) When "Apply proportions" is set to "3d view", changing image width to any value always makes height = 2,147,483,647; new height value makes width = 0.
Switching back from "Square", "4/3" and other proportions presets (that work fine) also causes this unwanted effect. If I want my image to keep proportions of 3d view but I need to change size I have to do it via standard "Create photo" window.
2) "Create photo with renderer" window doesn't fit to my screen height(1024x600px) - I don't see "Create", "Save" and "Close" buttons, even if I move or hide task bar. I use Tab key but I have to carefully count hits to avoid accidental skipping "Save" button when I'm finally satisfied with my image.
screenshot
I would be grateful for fixing it.
enkonyito
Post by enkonyito »
alax,
I can not reproduce it even by displaying the 3D view in a separate window.
Is this occasional or systematic?
Have others met the same kind of problem?
This will be fixed in the next version of the plugin that will be soon available.
EnkoNyito
alaX
Country: Poland
Post by alaX »
Thanks for reply.
I can not reproduce it even by displaying the 3D view in a separate window. Is this occasional or systematic?
- With 3D view docked (in main window) everything works fine.
- When I open "CPwR" first and then detach 3D view - it also works fine.
- Problem occurs every time I open "CPwR" when 3D view window is already floating(in my case - almost all the time). What I forgot to mention in my previous post - resizing this floating 3D view window manually(dragging edges) makes no changes to width and height fields in "CPwR".
Apparently, only me and I [;)] have met this problem - it happens on my both laptops - WinXP and Win7(32-bit).
enkonyito
Post by enkonyito »
By following your procedure, I was able to test the bug and find a solution. [:)]
EnkoNyito
alaX
Country: Poland
Post by alaX »
That's great! You're the man! [;)]
enkonyito
Post by enkonyito »
Version 1.3
- Added advanced settings for rendering properties
- Enhancement option to external brightness (sky with or without texture)
- Fixed a 3D view management bug in a separate window
- Fixed a photo panel resizing bug for small screens
- Other minor fixes and improvements
EnkoNyito
enkonyito
Post by enkonyito »
In case of problems with previous links (unavailability of sourceforge), use the one attached.
CreatePhotoWithRenderer-1.3.1.sh3p
(134.3 KiB) Downloaded 637 times
EnkoNyito
danger89
Post by danger89 »
I had a lot of issues with the default render engine, especially the quality of the image (yes I disable ceiling lights and add lights myself) ..
I got strange art-effects, white spots, dark spots -> know issues, never get fixed. I really couldn't found any solution. Exporting & importing to Blender is an alternative way, but way to complicated for now. . Until I found this plugin. Although I have still strange white spots with this plugin :(. It could because of my chandelier (lot of glass)...
danger89
Post by danger89 »
Maybe I'm too harsh, I really like that you put effort into the rendering engine. Kudos for that! [B-)] Don't get me wrong. But the future could be to switch to a better engine? Like from Blender perhaps.
I really like Sweet Home 3D actually, but the render engine should get replaced by a more modern engine using GPU.
enkonyito
Post by enkonyito »
Although I have still strange white spots with this plugin...
This plug-in also uses the default rendering engine.
Change rendering engine means respecting certain conditions for open source software like Sweet Home 3D.
EnkoNyito
