Photo Date-Time Metadata and Annotations
This topic has been viewed 7042 times and has 3 replies
digitaltrails
Country: Wellington, New Zealand, New Zealand
Post by digitaltrails »
I originally emailed info@eteks, but having got no response, I thought this forum might be the more correct place for development suggestions.
I've been experimenting with sun angles at different times of the year.  I found it useful to write the as-at date-time into the PNG to keep track of which date-times each images illustrates. For example:
   % exiftool -a ~/3D/test2.png
    ExifTool Version Number         : 9.34
    File Name                       : test2.png
    Directory                       : /home/michael/3D
    File Size                       : 30 kB
    File Modification Date/Time     : 2015:02:13 22:51:30+13:00
    Create Date Time                : 2015.02.13 22:51:16+13:00
    Date Time Original              : 2015.02.13 12:00:00+13:00
    Image Size                      : 400x223
As well as this I added code to optionally annotate the actual PNG graphic - note the Add Date check-box and displayed dates in the following image:
Patch is as follows (only tested with English):
diff -r -u ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/package.properties src/com/eteks/sweethome3d/swing/package.properties
--- ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/package.properties	2015-02-02 21:39:30.000000000 +1300
+++ src/com/eteks/sweethome3d/swing/package.properties	2015-02-13 21:44:57.009095228 +1300
@@ -1539,6 +1539,8 @@
 PhotoSizeAndQualityPanel.heightLabel.mnemonic=H
 PhotoSizeAndQualityPanel.applyProportionsCheckBox.text=Apply proportions:
 PhotoSizeAndQualityPanel.applyProportionsCheckBox.mnemonic=A
+PhotoSizeAndQualityPanel.addDateCheckBox.text=Add Date
+PhotoSizeAndQualityPanel.addDateCheckBox.mnemonic=D
 PhotoSizeAndQualityPanel.aspectRatioComboBox.view3DRatio.text=3D view
 PhotoSizeAndQualityPanel.aspectRatioComboBox.squareRatio.text=Square
 PhotoSizeAndQualityPanel.qualityLabel.text=Quality:
diff -r -u ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/PhotoPanel.java src/com/eteks/sweethome3d/swing/PhotoPanel.java
--- ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/PhotoPanel.java	2015-02-02 21:39:30.000000000 +1300
+++ src/com/eteks/sweethome3d/swing/PhotoPanel.java	2015-02-13 22:50:38.674348690 +1300
@@ -20,10 +20,12 @@
 package com.eteks.sweethome3d.swing;
 import java.awt.CardLayout;
+import java.awt.Color;
 import java.awt.Component;
 import java.awt.ComponentOrientation;
 import java.awt.Dimension;
 import java.awt.EventQueue;
+import java.awt.Graphics;
 import java.awt.Graphics2D;
 import java.awt.GridBagConstraints;
 import java.awt.GridBagLayout;
@@ -62,7 +64,13 @@
 import java.util.concurrent.ExecutorService;
 import java.util.concurrent.Executors;
+import javax.imageio.IIOImage;
 import javax.imageio.ImageIO;
+import javax.imageio.ImageTypeSpecifier;
+import javax.imageio.ImageWriteParam;
+import javax.imageio.ImageWriter;
+import javax.imageio.metadata.IIOMetadata;
+import javax.imageio.metadata.IIOMetadataNode;
 import javax.swing.ActionMap;
 import javax.swing.DefaultListCellRenderer;
 import javax.swing.Icon;
@@ -139,6 +147,7 @@
   private JButton                  createButton;
   private JButton                  saveButton;
   private JButton                  closeButton;
+  private long photoDateTimeOriginal;
   private static PhotoPanel        currentPhotoPanel; // Support only one photo panel opened at a time
@@ -761,6 +770,8 @@
         int bestImageHeight;
         // Check correct ratio if lens is fisheye or spherical
         Camera camera = home.getCamera();
+        // Seem to be in local time - adjust back to UTC
+        photoDateTimeOriginal = camera.getTime() - TimeZone.getDefault().getOffset(camera.getTime());
         if (camera.getLens() == Camera.Lens.FISHEYE) {
           bestImageHeight = imageWidth;
         } else if (camera.getLens() == Camera.Lens.SPHERICAL) {
@@ -781,6 +792,7 @@
       } else {
         // Compute 3D view offscreen image
+        photoDateTimeOriginal = System.currentTimeMillis();
         HomeComponent3D homeComponent3D = new HomeComponent3D(
             home, this.preferences, this.object3dFactory, quality == 1, null);
         image = homeComponent3D.getOffScreenImage(imageWidth, imageHeight);
@@ -802,6 +814,9 @@
             getActionMap().get(ActionType.SAVE_PHOTO).setEnabled(photoImage != null);
             if (photoImage != null) {
               getRootPane().setDefaultButton(saveButton);
+              if (controller.isDateShown()) {
+                annotatePhoto(photoImage, photoCreationStartTime, photoDateTimeOriginal);
             createButton.setAction(getActionMap().get(ActionType.START_PHOTO_CREATION));
             photoComponent.setImage(photoImage);
@@ -854,14 +869,16 @@
    * Saves the created image.
+   * @param showDate
   private void savePhoto() {
     String pngFile = this.controller.getContentManager().showSaveDialog(this,
         this.preferences.getLocalizedString(PhotoPanel.class, "savePhotoDialog.title"),
         ContentManager.ContentType.PNG, this.home.getName());
     try {
-      if (pngFile != null) {
-        ImageIO.write(this.photoComponent.getImage(), "PNG", new File(pngFile));
+      if (pngFile != null) {
+        writePhoto(this.photoComponent.getImage(), "PNG", new File(pngFile), this.photoCreationStartTime, this.photoDateTimeOriginal);
+        //ImageIO.write(this.photoComponent.getImage(), "PNG", new File(pngFile));
     } catch (IOException ex) {
       String messageFormat = this.preferences.getLocalizedString(PhotoPanel.class, "savePhotoError.message");
@@ -870,6 +887,51 @@
+  private void writePhoto(BufferedImage image, String string, File file, long createDateTime, long dateTimeOriginal) throws IOException {
+    SimpleDateFormat dateFormatter = new SimpleDateFormat("yyyy.MM.dd HH:mm:ssXXX");
+    String createTime = dateFormatter.format(createDateTime);
+    IIOMetadataNode textEntry1 = new IIOMetadataNode("tEXtEntry");
+    textEntry1.setAttribute("keyword", "CreateDateTime");
+    textEntry1.setAttribute("value", createTime);
+    IIOMetadataNode textNode1 = new IIOMetadataNode("tEXt");
+    textNode1.appendChild(textEntry1);
+    String photoTime = dateFormatter.format(dateTimeOriginal);
+    IIOMetadataNode textEntry2 = new IIOMetadataNode("tEXtEntry");
+    textEntry2.setAttribute("keyword", "DateTimeOriginal");
+    textEntry2.setAttribute("value", photoTime);
+    IIOMetadataNode textNode2 = new IIOMetadataNode("tEXt");
+    textNode2.appendChild(textEntry2);
+    IIOMetadataNode root = new IIOMetadataNode("javax_imageio_png_1.0");
+    root.appendChild(textNode1);
+    root.appendChild(textNode2);
+    ImageWriter writer = ImageIO.getImageWritersByFormatName("png").next();
+    ImageWriteParam writeParam = writer.getDefaultWriteParam();
+    ImageTypeSpecifier imageTypeSpecifier = ImageTypeSpecifier.createFromBufferedImageType(image.getType());
+    IIOMetadata imageMetadata = writer.getDefaultImageMetadata(imageTypeSpecifier, writeParam);
+    imageMetadata.mergeTree("javax_imageio_png_1.0", root);
+    IIOImage imageWithMetadata = new IIOImage(image, null, imageMetadata);
+    Object stream = ImageIO.createImageOutputStream(file);
+    writer.setOutput(stream);
+    writer.write(imageMetadata, imageWithMetadata, writeParam);
+  private void annotatePhoto(BufferedImage image, long createDateTime, long dateTimeOriginal) {
+    Graphics graphics = image.getGraphics();
+    graphics.setFont(graphics.getFont().deriveFont(10f));
+    graphics.setColor(Color.RED);
+    graphics.drawString(photoTime + " (" + createTime + ")", 20, 20);
+    graphics.dispose();
    * Manages closing of this pane.
Only in src/com/eteks/sweethome3d/swing: PhotoPanel.java.dateTimeOriginal
Only in src/com/eteks/sweethome3d/swing: PhotoPanel.java.keep
diff -r -u ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/PhotoSizeAndQualityPanel.java src/com/eteks/sweethome3d/swing/PhotoSizeAndQualityPanel.java
--- ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/swing/PhotoSizeAndQualityPanel.java	2015-02-02 21:39:30.000000000 +1300
+++ src/com/eteks/sweethome3d/swing/PhotoSizeAndQualityPanel.java	2015-02-13 21:52:42.458590124 +1300
@@ -72,6 +72,7 @@
   private JLabel                        heightLabel;
   private JSpinner                      heightSpinner;
   private JCheckBox                     applyProportionsCheckBox;
+  private JCheckBox                     addDateCheckBox;
   private JComboBox                     aspectRatioComboBox;
   private JLabel                        qualityLabel;
   private JSlider                       qualitySlider;
@@ -141,6 +142,14 @@
               : AspectRatio.FREE_RATIO);
+    this.addDateCheckBox = new JCheckBox();
+    this.addDateCheckBox.setSelected(controller.isDateShown());
+    this.addDateCheckBox.addItemListener(new ItemListener() {
+        public void itemStateChanged(ItemEvent ev) {
+          controller.setDateShown(addDateCheckBox.isSelected());
     this.aspectRatioComboBox = new JComboBox(new Object [] {
         AspectRatio.VIEW_3D_RATIO,
         AspectRatio.SQUARE_RATIO,
@@ -196,6 +205,7 @@
             applyProportionsCheckBox.setSelected(notFreeAspectRatio);
             aspectRatioComboBox.setEnabled(notFreeAspectRatio);
             aspectRatioComboBox.setSelectedItem(controller.getAspectRatio());
+            addDateCheckBox.setSelected(controller.isDateShown());
@@ -309,6 +319,8 @@
         PhotoSizeAndQualityPanel.class, "heightLabel.text"));
     this.applyProportionsCheckBox.setText(SwingTools.getLocalizedLabelText(preferences,
         PhotoSizeAndQualityPanel.class, "applyProportionsCheckBox.text"));
+    this.addDateCheckBox.setText(SwingTools.getLocalizedLabelText(preferences,
+        PhotoSizeAndQualityPanel.class, "addDateCheckBox.text"));
     this.qualityLabel.setText(SwingTools.getLocalizedLabelText(preferences,
         PhotoSizeAndQualityPanel.class, "qualityLabel.text"));
     this.fastQualityLabel.setText(SwingTools.getLocalizedLabelText(preferences,
@@ -333,6 +345,8 @@
       this.heightLabel.setLabelFor(this.heightSpinner);
       this.applyProportionsCheckBox.setMnemonic(KeyStroke.getKeyStroke(preferences.getLocalizedString(
           PhotoSizeAndQualityPanel.class, "applyProportionsCheckBox.mnemonic")).getKeyCode());
+      this.addDateCheckBox.setMnemonic(KeyStroke.getKeyStroke(preferences.getLocalizedString(
+          PhotoSizeAndQualityPanel.class, "addDateCheckBox.mnemonic")).getKeyCode());
       this.qualityLabel.setDisplayedMnemonic(KeyStroke.getKeyStroke(preferences.getLocalizedString(
           PhotoSizeAndQualityPanel.class, "qualityLabel.mnemonic")).getKeyCode());
       this.qualityLabel.setLabelFor(this.qualitySlider);
@@ -394,6 +408,7 @@
     JPanel proportionsPanel = new JPanel();
     proportionsPanel.add(this.applyProportionsCheckBox);
     proportionsPanel.add(this.aspectRatioComboBox);
+    proportionsPanel.add(this.addDateCheckBox);
     add(proportionsPanel, new GridBagConstraints(
         0, 1, 4, 1, 0, 0, GridBagConstraints.CENTER,
         GridBagConstraints.HORIZONTAL, new Insets(0, 0, 0, 0), 0, 0));
@@ -423,6 +438,7 @@
     this.widthSpinner.setEnabled(enabled);
     this.heightSpinner.setEnabled(enabled);
     this.applyProportionsCheckBox.setEnabled(enabled);
+    this.addDateCheckBox.setEnabled(enabled);
     this.aspectRatioComboBox.setEnabled(enabled);
     this.qualitySlider.setEnabled(enabled);
diff -r -u ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/viewcontroller/AbstractPhotoController.java src/com/eteks/sweethome3d/viewcontroller/AbstractPhotoController.java
--- ../SweetHome3D-4.6-src-original/src/com/eteks/sweethome3d/viewcontroller/AbstractPhotoController.java	2015-02-02 21:39:30.000000000 +1300
+++ src/com/eteks/sweethome3d/viewcontroller/AbstractPhotoController.java	2015-02-13 21:52:42.439590123 +1300
@@ -51,6 +51,7 @@
   private int                         quality;
   private float                       view3DAspectRatio;
   private int                         ceilingLightColor;
+  private boolean                     dateShown;
   public AbstractPhotoController(Home home,
                                  UserPreferences preferences,
@@ -309,4 +310,14 @@
                                 Object propertyValue) {
     this.home.setVisualProperty(propertyName, propertyValue);
+  public boolean isDateShown() {
+    return this.dateShown;
+  public void setDateShown(boolean dateShown) {
+    this.dateShown = dateShown;
Re: Photo Date-Time Metadata and Annotations
Nice idea! How about the geo fields (LAT/LON) which also have a great impact on how the sun renders... ?
digitaltrails
That would be possible.
Extra info such as the render camera settings would definitely be useful.
I did consider embedding the geo data, but I wasn't sure I wanted GPS coordinates to my house buried inside the images, especially if it was a overhead plan view (I'm sure you're all nice people, but...). If this were to be done, I think it would have to be controlled by a setting that would default to off.
If the eTeks decide to fold this code in, I don't mind putting it some effort to include a few more attributes.
Initially I wasn't sure whether displaying text on the image was totally necessary. But metadata embedded in PNG's is only supported by a few imaging tools. It turns out there is no well established metadata standard for PNG's (that came as a bit of a shock). That pushed me to experimenting with an option for annotating the actual image.
It turns out there is no well established metadata standard for PNG's...
Yes, isn't that strange? Has puzzled me too (even if ExifTool, I think, has set some sort of standard?). But then, (standardised) meta-data in general, is not very often a priority. About the GEO data, I certainly see the pricacy issues (could be a good idea to remove compass data when posting .sh3d files). ok
