My 3D image, for an unknown reason, suddenly got very small, about 1/4th of its previous size. How do I zoom in the image to get it back to full size?
Thanks in advance
3d zoom
This topic has been viewed 9659 times and has 5 replies
Re: 3d zoom
You must have added a (small) object in your plan, making its overall size much larger.
Choose the menu Edit > Select all to find it, and read also the FAQ Is it possible to manually set the rotation center of the 3D view in Aerial view mode? which offers an other solution.
nail59.6768
- Country: USA
Re: 3d zoom
I found a solution that seems to work. There is a cross symbol in the upper left corner of the 3D view. Left click and holding down on the top of the cross zooms in on the 3D display. I don't know if this is supposed to happen but it returned my display to the proper size. I tried the FAQ solution you mentioned, it didn't work but thanks for the response.
Cheers
John
Cheers
John
Re: 3d zoom
Maybe it would be time to read the user's guide or the help included with Sweet Home 3D. You could learn many useful tips.
Re: 3d zoom
are there plans to make the tutorial also in other languages, like dutch?
Re: 3d zoom
Translations are made by volunteers, so if a volunteer proposes his contribution, no problem, otherwise it won't happen. But the Dutch version of the included with Sweet Home 3D help is almost complete and will give you already more information than the user's guide.
