1/ How to geolocate our field as in Sketchup?
RE:
http://www.sweethome3d.com/support/foru ... hread,4406
2/ How to view the shadows'sun of building onto the ground, according to the geo position, date & time (as in Sketchup)?
I use V4.2 and when I go Tools>Advanced photo creation
No such menu appears
http://www.sweethome3d.com/blog/2010/04 ... ug_in.html
Geolocation & sunshine shadows projection
This topic has been viewed 6272 times and has 5 replies
Re: Geolocation & sunshine shadows projection
That thread is 6 yrs old....
At least since version 2.6 (I think) the program takes your geographic location into account.
Please do the following:
- with the program open, hit F1;
- in the search field type compass;
- read the help text;
- come back if you need more help.
And uh... the advanced rendering plug-in is NOT compatible with SH3D since version 3.2.
Thanks nearly there, for me as I have the French version it's "boussole"
I still want to view the sun's shadows onto the ground not onto the building.
P.S. It should be written in the help that you need so slide the quality cursor to better in order to have the field date&time.
OK I found, one needs to move away the view point.
Adding this to the help would make it perfect.
Thanks for the help!
jeannieburt
So, is there an advanced rendering replacement for newer versions, specifically 4.4?
The features of this plug-in were simply added to Sweet Home 3D.
