I can't open preferences
This topic has been viewed 8532 times and has 11 replies
Kassandra76
Post by Kassandra76 »
Hello to all, i am new in here and finally i found how to change the meters, but my problem now is bigger because i can't open the preferences tub to do the change. it shuts me out. I do not know why and only the preferences, everything else works just fine. Please please Help! [:)]
Re: I can't open preferences
Please read the FAQ Sweet Home 3D crashes when I want to edit preferences, print, create a photo or create a video. What can I do?
matludlam
Post by matludlam »
Hi, I have read the FAQ but that seems to be for using the web version. where can I get a version that I can down-load?
Thanks.
Mat,
Did you notice the link Download at the top of every page?
Any guess where it would lead to? [:))]
rosariopagano
Post by rosariopagano »
I'm in the same situation. I'm on linux with kubuntu 11.10.
I've downloaded the new 3.4 version but I'm the same problem with 3.3.
When I try to open preferencies SweetHome crash. Also if I try to create a Photo.
Following the link indicated I've tryied to use SweetHome3D-NoOffscreen.jnlp with no success.
Javaws with this file open a popup with same ouput about an error on download.
If I open it in browser directly I receive the same error.
I used SweetHome many times (great program) and I need to use it more but with version 3.3 e 3.4 I'm in trouble to take photo.
Any suggestions?
Thanks in advance
Rosario
rosariopagano
here you are the error message from javaws which is the same from web browser:
net.sourceforge.jnlp.LaunchException: Fatal: Read Error: Could not read or parse the JNLP file.
at net.sourceforge.jnlp.Launcher.fromUrl(Launcher.java:491)
at net.sourceforge.jnlp.Launcher.launch(Launcher.java:283)
at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:199)
at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:51)
at java.security.AccessController.doPrivileged(Native Method)
at net.sourceforge.jnlp.runtime.Boot.main(Boot.java:165)
Caused by: java.io.IOException: www.sweethome3d.com
at net.sourceforge.jnlp.JNLPFile.openURL(JNLPFile.java:255)
at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:185)
at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:162)
at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:148)
at net.sourceforge.jnlp.Launcher.fromUrl(Launcher.java:477)
... 5 more
Caused by:
rosariopagano
Hans,
I've solved problem for jnlp. My proxy was in trouble during my tests.
Now I've started it with javaws and works fine.
Now a question. How can I modify the Sweethome3d script to run it without any web connection?
I'm not always connetted so I've installed the sw in my laptop.
Rosario
Rosario,
On the Download page you can download installable versions for 32 bits and 64 bits versions of Linux. I use the 64 bits version, and it works fine with (L)Ubuntu 11.10.
If you have problems, try uninstalling ALL versions of Java on your computer (Sun Java and Iced Tea). Then install the downloaded version of SH3D.
rosariopagano
Hans,
I use 32bit on K(de)Ubuntu. I've just downloaded it (3.3 and 3.4 version) with those problems.
Rosario
rosariopagano
Hans,
in SweetHome3d script you point every lib with the absolute path of your suite.
How can be possible to use another java?
We don't are on windows....
May be is correctly the offscreen test to create problem. There is any parameter I can put on java line like mem to avoid it?
Rosario
