Total posts in this thread: 2
Previous Thread This topic has been viewed 3356 times and has 1 reply Next Thread
orwe8
Germany
Dimensioning/Bemaßung
Hallo,
als Maßeinheit habe ich mm eingestellt. Die Bemaßungen werden jetzt in mm angezeit, jedoch auf cm gerundet. (Statt 5432 mm wird 5430 angezeigt). Wie kann ich die rundung abschalten?
Hello,
I have set the unit of measurement to mm. The dimensions are now set in mm, but rounded to cm. (5430 is displayed instead of 5432 mm). How can I switch off the rounding?
[Oct 27, 2019, 2:19:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Dimensioning/Bemaßung
The rounding depends on the current zoom factor. Zooming in will let you create dimensions with higher precision. You may also type directly the length you want with <enter> key (see included help about dimensions).
[Oct 28, 2019, 10:55:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
