Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Dimensioning/Bemaßung |
| Print at Oct 6, 2026, 1:49:19 AM | View all posts in this thread on one page |
| Posted by orwe8 at Oct 27, 2019, 2:19:16 PM |
Dimensioning/Bemaßung Hallo, als Maßeinheit habe ich mm eingestellt. Die Bemaßungen werden jetzt in mm angezeit, jedoch auf cm gerundet. (Statt 5432 mm wird 5430 angezeigt). Wie kann ich die rundung abschalten? Hello, I have set the unit of measurement to mm. The dimensions are now set in mm, but rounded to cm. (5430 is displayed instead of 5432 mm). How can I switch off the rounding? |
| Posted by Puybaret at Oct 28, 2019, 10:55:02 AM |
Re: Dimensioning/Bemaßung The rounding depends on the current zoom factor. Zooming in will let you create dimensions with higher precision. You may also type directly the length you want with <enter> key (see included help about dimensions). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 1:49:19 AM |
