Previous Thread This topic has been viewed 2300 times and has 2 replies Next Thread
xpatux
Variable names on dimensions
Is there a way to use variables to fill positions (x,y), dimensions, etc?
I mean, I have many items that have the same width and would like to change it modifying just one variable.
Is that possible?
[Jul 9, 2018, 10:36:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Variable names on dimensions
There’s no variable but if you want set the same size to a group of objects, select them (with a selection rectangle or thenshift key to add an object to current selection), choose Furniture > Modify menu item and set the value(s) you want in the modification dialog box.
[Jul 10, 2018, 2:09:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xpatux
Thanks Emmanuel,
That is actually helpful to set some attributes, but I need to do something more.
I'm designing a furniture made of blocks of different sizes and positioned on different places to form, let's say, a box. The "X,Y, elevation" coordinates of one block are dependant on another blocks width or position. I would like to change, for example, the depth of a block, and then coordinates of the other blocks will change automatically.
[Jul 10, 2018, 10:59:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
