Re: Sweet Home 3D 6.0
In the software setup interface or software installation interface, add a memory size setting option. just like SweetHome3D.l4j.ini
Maybe in a future version...
The default use of 0.9G in software 32 is very small, and the 64 bit 4G is too small.
In 32 bit, a higher value won't work. In 64 bit, the default max is half of the available RAM.
Is max mem 14.2 Gb?
When run in 64 bit, the working limit must be the RAM size available on your computer when Sweet Home 3D runs.
To all <?> Ubuntu users who have problems running the beta version.
Thanks to the help of UbuntuBirdy I now can try the beta version 6. Here are the program lines you need:
[Desktop Entry] Version=1.0 Name=Sweet Home 3D BETA 611 GenericName=Interior 2D design application with 3D preview Generic Name[de]=Innenraumplaner Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview Comment[de]=Innenraumplaner zum Auswählen und Platzieren von Möbeln auf einem 2D-Hausplan mit 3D-Vorschau Path=/home/hans/SweetHome3D-beta611 Exec=sh -c "/home/hans/SweetHome3D-beta611/SweetHome3D-Java3D-1_5_2" %U Icon=/home/hans/SweetHome3D-beta611/SweetHome3DIcon.png StartupNotify=true StartupWMClass=com-eteks-sweethome3d-SweetHome3D Terminal=false Type=Application Categories=2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java; MimeType=application/sweethome3d; Name[de_CH]=SweetHome3D BETA 611
Note the following: - you can change the Name and GenericName to whatever you like - you can leave out the Comment lines - you can change [de] and [de-CH] to your own language - in the path names change "hans" to your own user name - make sure that the path name /SweetHome3D-beta611/ points correctly to your file (name and location) - open a Text Editor and copy the above text - save and name the file xxx.desktop where xxx is the name you want - then copy the script to /home/hans/.local/share/applications/ - this is a hidden file, so you need to do CTRL-H to show the file
- under the start button, type SW and SH3D should show up
Thank you very much Birdy!!!
[Edit 1 times,
last edit by hansmex at Sep 24, 2018, 10:40:43 PM]
Poland
So many new great features - oh, Emmanuel, please don't stop Due to "3d error" I had to install 6.0 beta 11 with "j3d.version=1.5.2" (Win 7, 32bit) and now it works nice.
Thank you very much Birdy!!! H
Glad I could help you, Hans.
There are two great programming highlights since time immemorial: once Linux and of course SweetHome3D! The result is a law of the universe: who's able to use SweetHome3D on a Linux-System, will be happy! And of course I will try to make as many people happy as possible by showing them how to use SweetHome3D on Linux.
A humble servant of the universe Pascal
Pascal
Thanks for your feedback
Ceciliabr, I already noticed the difference between the requested amount of max memory and the actual value reported in the About dialog box. It's not a bug, but Java probably rather uses the difference for internal management (see this technical article if you want to learn why).
digitaltrails, fortunately you had the idea to test com.eteks.sweethome3d.j3d.useOffScreen3DView. It's probably another solution that I should better document, just because I keep in mind to test it from time to time to check if it still works.
bdfd, the behavior you noticed is normal. As said in a previous post:
As soon as an object is deformed, its size can be changed only proportionally, otherwise this could lead to strange shapes. If ever you need a wider or deeper or higher object, first reset its shape, change the dimensions you want, and deform again its shape.
Emmanuel,
Thanks to UbuntuBirdy I'm finally able to test beta 11 under Ubuntu.
There's a few things I want to share. 1 - CSV export This feature works fine, but isn't perfect. When I tested an earlier version under Windows, I noted that values were exported as text, not as numbers. This hasn't changed in the beta 11. In an earlier message you wrote that the exported CSV is correctly interpreted by Excel and LibreOffice. Can you explain how you do that? Here's a spreadsheet that shows what happens when I import CSV in LibreOffice, and what you need to do to be able to use the exported data. Am I doing it the wrong way? a - The green colums show what is exported from SH3D. In row 17 you can see that the totals are 0, meaning that you can't use the exported values, because they are text. b - The pink columns show how we need to change the imported text: a column with the currency, than columns with numerical values. If you look at the formula, it's easy enough to extract the wanted numerical value from the text, but I think it's beyond the spreadsheet knowledge of most people. c - The yellow columns show what we really need: values. Currently we need TWO conversions: first step (pink) is separate text and values, second step (yellow) is Paste-Special to obtain pure values (without underlying formula).
It also means that in the current situation we MUST keep the original until we have performed the second step, because when we delete the original info after the first step, all values will revert to zero.
2 - Multi-line text The possibility to have multi-line text is very welcome. I notice that changing the text orientation from left to center or right, the box around it moves. Ideally the box stays in the same spot, and only the text moves within the box. Also, it would be nice if the text interface window had the option "Part of base plan".
I will do more testing in the coming days.
Thank you once again for all the splendid work!!
