Previous Thread This topic has been viewed 2902 times and has 2 replies Next Thread
k1r2t3n
Floor Textures with gaps from lower level walls
Hi there,
I would appreciate your help:
I am currently building our new home in sweet home and started to apply textures. unfortunately the textures seem to show gaps where the lower level walls are. see screenshot. What is wrong?
https://www.dropbox.com/s/d59csregk2kk5id/gapsintextures.png?dl=0
thank you.
Kirsten
[Apr 25, 2018, 11:50:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Re: Floor Textures with gaps from lower level walls
What is wrong?
The height of walls in level UG are at least as the elevation of the level EG.
Solution:
Verify the height of walls on level UG and reduce them.
or
Increase the elevation of level EG.
PS Don't forget: every level have a floor thickness; You must take it in consideration.
[Apr 25, 2018, 8:50:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
k1r2t3n
Dear Dorin,
thank you! I added another 1cm to the elevation. This did the trick!
Perfect!
Cheers, Kirstne
[Apr 25, 2018, 9:12:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
